jayden
Everything posted by jayden
  1. Thanks m8 I brought a brand new maf from z1 and that didn't work but I'm gonna take your advise and get the alternator rebuilt and see if it sorts the voltage and see if that sorts my problem appreciate your help :) Sent from my G3221 using Tapatalk
  2. Not running the selin kit as removed the things that had issues the feature pack update in the nistune has been found to be corrupted they have now released a new update that supposed to stop the problem so now back on old setup, alternator was fine last time I checked I've been told as its only dropped 0.7 volts it shouldn't effect things like mags and injectors as there pretty robust, it was fine on full load and fuelling was constant never been lean now just over fuels and runs lean on idle and cruise, would you recommend swapping the alternator for a new one and try that? Really thought it would be the maf not reading right hense giving weird fuelling but that's been ruled out not sure what else could effect afrs so badly? Sent from my G3221 using Tapatalk
  3. The tuner has been looking after my car for 5 years and never had a problem till now the map and setup I'm running on was the same one he mapped for me and I ran with with no problems for months it was o ly since going nistune problems happened so I reverted back to old setup thinking it would be OK but it's now not I did question wether something had gone wrong with the nistune as there was a fault fount with the feature pack after investigation maybe it caused a short somewhere just don't know what else to try and wether to just cut my losses and have it stripped for parts Sent from my G3221 using Tapatalk
  4. Ruining 630bhp Full forged block nismo 740cc injectors 2.5" intercooler piping with ams side mounts full 3" ams/labree exhaust, apexi I take aeromotive fpr, walbro 340lp pump, devilsown water methanol kit and a load more stuff to breaks suspension ect, quite a similar thing to you then I had to have fuel pump mod to so its on constant I did wonder if this had anything to do with it just seems since going nistune all my problems have started but since I reverted back to the old setup it's never been right and now got this latest issue Sent from my G3221 using Tapatalk
  5. hi guys so i have a whole lot of issues at the minute so please bare with me as this will be an essay: so first off then a bit of back story in November of last year i upgraded to a nistune ecu and selin duel intake kit and it caused the car to run stupidly rich on boost below 10 on afr resulting in power loss and on top of that after every start up the car would fuel differently on cold start up to the point where the mapper would set up cold start get i t to where it was better then come back the next day and it would be well off again on top of this on the power runs the cigarette lighter would lose power and there was a electrical squeal picked up through the headphones while mapping,now i had none of these issues prior to going nistune and duel intake. with me so far? ok so the logical step was to revert back to precious set up (single maf and previous map which ran great) we tried several different ecus combinations but even though being on the same map each behaved different on fueling for example my ecu and map was fine fueling where it always was but the map on the mappers personal nistune didnt fuel right now whats weird is when i originally had this map it was first mapped on his personal nistune then burned on to a chip then put into my socketed ecu so we were stumped why it didnt work. i then took the car away and used it it idled from cold for a month fine but afr and afr on boost was good but i had a problem with it going lean on cruise after prolonged driving , it was fine for say 45 mjnutes journey but anymore after that and is miss behaved and also had the cigarette lighter socketed continuously shutting off when coming on boost (checked for shorts to it couldn't find any) also i had noticed the voltage on my gauge when running was between 13.2-13.3 where it had been 14.1 when running before. then the problems really started the car would overfuel on cold start and as soon as you tap the throttle it would overfuel to the point the car would almost cut up but once the car was driven and up to temp idle fuelling was fine and constant but was still is the issue of going lean on cruise plus now on boost in 3rd,4th,5th it would run 11.0-11.3 which it was mapped to on afr but in 2nd gear would be richer at 10.5-10.6 and i was advised if anything it should be cleaner in 2nd. after a long discussion i was told it would need a new maf so i ordered a genuine one from z1 put it in and it made everything worse it would now overfuel on boost under 10.0 on afr and overfeul on cruise and cold start idle was worse so put the old maf back in, several people suggested the maf may have been on its way out when mapped and needing the map tweaking but after speaking to the tuner and considering i had a year of no problems on the map it simply couldnt be the case. so to where i am now things have got worse its now any start up after leaving car to cool for say an hour it will overfuel when hitting throttle to move until fully up to temp,and now at the weekend it went to scary lean on idle and cruise 19.0 on afr so had to shut it off and leave the car as wasnt safe, i let it cool down and still running lean but if you tap throttle it went rich to 10.0.it still has the lower voltage when running at 13.2v but also has a slow starter like it gos to start then no noise then just burst in to life all in the turn of a key, yes battery was changed and still the same problem so now i am completely stuck i just dont know where to begin or look i had a perfectly fine working car before trying to go nistune and since then its just gone downhill its taken me 5 years to get the car to this stage and ive still not properly used it i dont want to give up i want to sort it but my mapper is very distant and doesn't seem interested in sorting the problemso just looking for suggestions/advice and wether anyone has ever had a similar problem, hope you managed to stick through all the content and sorry for th essay lol
  6. as title doesnt matter if glass is clear or orange or scratched as going to be cut up for a project but need it sent with next day delivery so arrives for friday anyone got one lying around?
  7. got a link to these wobble nuts ? interested to see now
  8. well thats me told never knew you can get wobble nuts, cant say id like to run a high hp car on wobble nuts tbh but if your having no issue must be fine
  9. the zed doesnt use bolts its stud and lugs so wobble bolts is not an option
  10. The winters are 10 months long these days lol , and I was just joking around m8, if I didn't lose my garage space I would be the same but now it's out in the elements all the time there's really no point for me not to get in it whatever the weather Sent from my G3221 using Tapatalk
  11. Weather is not looking to clever will more than likely be damp and raining however if I can venture out on semi slick tyres and brave the elements so can everyone else [emoji23] but then again I like to drive mine not just garage it for 10 months of the year ? Sent from my G3221 using Tapatalk
  12. Awesome m8 congrats again, you must be on cloud nine right now :) for anyone else meeting at Toddington service we will be there for 10am leaving at 10 15 [emoji106] Sent from my G3221 using Tapatalk
  13. Il meet you at Toddington m8, is that your engagement present to your self lol [emoji23] Sent from my G3221 using Tapatalk
  14. first episode was really good this series but the second was utter rubbish imo was hoping for better after the promising start,the presenters have gelled together nicely but will never be as good as previous 3 but its a motor show at the end of the day so il watch it regardless of who is presenting
  15. toddington
  16. anyone meeting at the services again before hand like last time?
  17. Wow! Not jealous at all [emoji6] have to let me know the details when you can! first your mx5 is in a music video now your zed in a TV show well played sir [emoji3] Sent from my G3221 using Tapatalk
  18. Not sure what your budget is tom but there's a very nice red one on ebay for 7k low mileage mechanical upgrades and body wise relatively standard apart from wheels have seen it in the flesh and it looked great he's a member too https://www.ebay.co.uk/itm/Nissan-300zx-Twin-Turbo-Manual-Z32-Fairlady-Z-1-Owner-27k-miles/162811691594?hash=item25e855424a:g:H5MAAOSwcj1aOS7k&_trkparms=gclientid%3DfxnyJcfj0BbWlrzaWriQLhBpK5bn0ZEumI2pfLxAR9p4fM-Rp_d-l8Qd6jb2Nigm&_trksid=p2489528.m4335.l8656 Sent from my G3221 using Tapatalk
  19. Did someone say diffuser [emoji14] pic of my modified zed to so funkysi can bring up his lunch lol Sent from my G3221 using Tapatalk
  20. yes completely agree with you it all depends on what you use your car for the reasons you stated are exactly why i went for them i hardly bother going out in the wet as it gets boring spinning up in every gear so max grip in dry conditions was the factor for me,unfortunately the rsr only go's up to 285 max width which is too skinny for my new wheels, so now moving on to the tri ace racing kings as they do the 315 size will be going for in soft compound. i have herd a lot of good things about them so hopefully will be as good as the rsrs if not better :)
  21. thats fair enough im just speaking from personal experience with the tyres the pilots 3s and eagle f1 never gave me anywhere near the grip i have now i can actually launch properly with the federals will be moving onto the tri ace next year as alot of people ive spoken to rate them and they cant be that bad if people are using them in competition and winning so worth a go i think
  22. another optionif you want max grip is either federal rsr's or tri ace raceing king series semi slicks, might not last as long but give way more grip than eagles or pilot sport IMO and there half the price, i couldn't put my power down with eagles f1 or pilot sport 3's but now no problems on the semi slicks and there not to bad in the wet either surprisingly
  23. i looked into those myself last summer i spoke with iconic dynamics the guys who make them but they will only accept bank transfer as payment as they had problems via paypal with uk customers while they seem a legit company sending over 400 via bank transfer was to risky for me incase i never got the parts, i did look into it over here and no one has done it there are a few who have done a diy version stateside which is the route i will be experimenting with on a spare set of stock units its just a case of cutting out what you dont need with a dremmel leaving the indicators in then some fiberglass to smooth it all , use black tint spray over indicator lens thats left should look pretty similar to the ones above
  24. And you bud look forward to seeing our cars out together [emoji4] Sent from my SM-G920F using Tapatalk
  25. good to see you guys again and your awesome zeds look forward to next years :)
