Wobble bolts or Hub Adaptors
Hi Guys,
I am searching for a set of LM reps for the Z and running into serious lack of availability for a staggered set in 19". So my thoughts are,
do I get a set of 5x112 wheels and use wobble bolts or do I look for a set of 5x120 8.5 and 9.5j 19's and go for hub adaptors? If I go for the second
route the minimum adaptor is 20mm, could I get away with that and if so what would the offset need to be to allow for the spacer?
Hopefully someone will know how I can get around this wheel issue!
Cheers guys!
the zed doesnt use bolts its stud and lugs so wobble bolts is not an option
And yet I use them on my Zed so wobble nuts ARE an option!
My rims are 5x112 and I've had zero issues in nearly 2 years of running them. :thumbup1:
well thats me told never knew you can get wobble nuts, cant say id like to run a high hp car on wobble nuts tbh but if your having no issue must be fine
Mine doesn't get used on track or anything like that but, for road use, I see no issue with them. Not sure I'd want to track it using them, in fairness.
As I said, there's a 1mm difference per stud between the hub PCD and the rim PCD. My current wheels are absolutely solid and have been since day one.
got a link to these wobble nuts ? interested to see now
Hi Guys,
Cheers guys!
You talking BBS LM reps or NISMO LMGT reps?
Thanks for the responses guys, I need to do some thinking before pulling the trigger on 5x112.
Hi Nick, BBS LM Reps really, why?
Check your PM
