RoboGaz
Everything posted by RoboGaz
  1. Had the same problem with my brake pipes last year and was told the same thing. I took it to my local friendly mechanic (who also does MOT's) and he managed to replace the bad bits of pipe by just removing the diff and getting in there somehow as he didn't fancy dropping the whole rear axle. Anyway he did it, passed it and it was fine, went through the MOT again this year without a hitch. Still cost me nearly £300 to get it done though :( Gaz
  2. There must be something up with the car http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160169016885 Is he desperate or hiding something ?? Looking at the feedback I'd be suspicious. Gaz .
  3. Try driving a bit faster, you might catch one up :)
  4. I was driving back from Stowmarket in my Z and spotted you turning up the Barking road. Followed you a few cars back until you turned off into Foxglove Avenue. Was that you steevo ? Gaz
  5. £175 for the door rubber and £40 for the bit on the Targa ........ plus VAT. Well that's what I paid recently. I tried various things to get rid of the leak, in the end decided the best thing was to do it properly and replace the rubber. It was a pretty straight forward job and no more leak. You might be able to get a second hand one cheaper, but I wouldn't reccommend it as there's one corner that has some sticky pads, so not sure they'd work as well second hand. Gaz
  6. Spotted at about 5.20pm on the one way system near Cineworld. Had those Ferrari style rear lights and looked in good nick. Belong to anyone on here? Gaz
  7. When I first got mine it had a wobbly rear end. It was more noticeable over bumps and on one particular stretch of road. I'm sure it felt worse than it looked from behind. The fix for me was 2 new Hicas ball joints, luckily it was the outer ones. Gaz
  8. If you want to do the resistor mod then it's the R10 resistor and the 33K ohm one needs to be replaced with a 20K ohm one. It's not to bad a job as long as you're ok with a soldering iron. Took me not much more than an hour to do and that included removing the clocks. Gaz
  9. There are a few of us on the forum around Ipswich. I'm off on holiday for 2 weeks on Friday otherwise I'd gladly help out. If you have no luck finding the problem with SuffolkZX's Conzult then LPS over at Martlesham know the Z well - http://www.lpsauto.com/ Good luck and hope you get it sorted. Gaz
  10. Thanks for heads up guys. I got the new door and targa rubber today so fitted them. Poured water over the roof and hey presto no drips on the seat so that's one job done, but noticed water p**sing into the drivers footwell via my fuse box again. Took it all apart and found it was indeed the targa pipe that had disconnected from the tube that takes the water out near the wing, so it was pouring into the car instead. It was a hell of a job to get it back, the tube had shrunk (I assume with age) and no amount of pulling got is near the outlet pipe. I ended up cutting some of the outlet pipe and using this to connect an extension to the tube. Anyway, a bit of a Heath Robinson job, but it works and no more water leaking into the fuse box. I now have the carpet up and the dehumidifier running in the car. So thanks once again, it would've taken ages to find the problem without the pointers. Gaz
  11. Came back to mine after buying some grub for dinner to spot you parked opposite :) Gaz
  12. Thanks for the pointers guys, I'll have a good look on a dry day and try all the different places to see where it's coming in. Gaz
  13. The pipes at the rear are a real pig to do so I'm not suprised most garages won't touch them as it's often a case of dropping the rear end to get to them. I don't know anyone in your area, but keep looking as I just got mine done last month and after a few problems finding somewhere to do it, I got the mechanic 400 yards up the road to do it. He didn't seem phased at all and just removed the rear diff to get in there, but he did swear a bit afterwards about the job. I just had the rear pipes replaced and got some braided brake hoses fited at the same time and it was about 10 hours labour. Gaz
  14. The one inisde the drivers footwell, it's all very wet in there and the connectors had water dripping out of them when I pulled them apart. Is this likely to be coming in through the scuttle somewhere or windscreen or is there another likely reason? anyone had a similar problem before. The long story ........... I found the problem because my battery kept going flat after a few days, it was fine if I drove it every day. Anyway I did a bit of experimenting and thought I had an altenator fault, but my multimeter told me a different story. Battey was 12V and altenator was charging at 14.3V when the engine was running. So I turned everything off and checked to see how much current was being drawn with the ignition off. I was suprised to find 1.7A !!!!. So I started pulling everyhting apart and thought I'd pull the fuses one by one ......... until I heard a hissing noise, you know the sort that makes you think hmmmm that doesn't sound good. Started to disconnect the cables around the fuse box to find water dripping out of the connectors and then the hissing stop. So I think I've found my long term electrical problem, green plugs and lots of short ccts. Now I just need to rectify it. My driver side targa has also started to leak after I took the lid off for a day a couple of weeks ago :cry: new rubbers all round me thinks :cry: :cry: Gaz
  15. Check some of the smaller pipes right at the very back of the engine on top. I had a similar problem last year and it was one of these (passenger side for me), looked fine until a closer inspection showed that the rubber pipe was not on tight. On kick down mine would pull for a few seconds then die, I'd ease up and kick down again and it'd pull for about 3 seconds again. Gaz
  16. Sounds similar to a problem I had last summer. If you lift your foot off the accelerator momentarily and then whack it down again, does the car take off again for a bit? If so then I had this but at slightly lower revs and it turned out to be a loose boost pipe and was quite hard to spot until I decided to have a closer inspection and check they were all pushed on correctly. Gaz
  17. That would do it if you want all the dials looking like the UK ones, it's not the route I took but then I only wanted the speedo converted to MPH on mine, so I just replaced the resistor, everything else is J spec. It's quite a straightforward job getting the clocks out, just a few fiddle screws in there that are hard to see holding the bottom end of the clocks in, otherwise should be less than an hour to get them out. Gaz
  18. The garage I had my car booked into for a big fix has just rung me to say his partner has left the business and he now cannot repair my car until he has employed someone else. This leaves me with a car and no MOT until it's fixed. So anyone used any garages around the Ipswich area before that they can recommend as I use the car most days to get to work, so can't really do without it. The car needs new rear brake pipes as they are all corroded (badly) which means dropping the rear axel, which needs two people to do safely and I just don't have the facilities at my house to do this (no garage and no flat area). Cheers, Gaz
  19. Hi Jack, I'll keep an eye out for you in future as I'm probably driving that route 2 or 3 times a week at the moment. No, the car did not pass, it failed on the rear brake pipes being corroded which is a fairly hefty job. The garage was quite worried about the pipes as they said they were really bad :( so that's the next job on the car. Should be back on the road in early January. Gaz
  20. This morning just before 9.00. I was in my Z on the way for an MOT and passed him, so we almost had a mini convoy there for a few miles :) Your car looked as good as ever Jack :cool: Gaz
  21. That would be about right, I thought it looked a lighter shade of yellow but wasn't sure if it was the fading light or not.
  22. I'd just parked my Z in the nightclub car park and was walking to the station, so it was about 8.55am. Spotted a very nice looking Black Z driving towards the town centre from the station. Wish mine was that clean :cool: Gaz
  23. Spotted it on West End Road around 4pm (might have been a bit later) last Thursday (23rd Nov). It was getting dark but I'm sure it was a yellow one. Gaz
  24. Got mine this morning and would like to thank everyone who put the effort into this as it's a top job. Gaz
