tommyl620
    Ireland
Everything posted by tommyl620
  1. Iam doing track day in the morning and want to disconnect the abs Which fuse should i pull the relay beside the pump in the boot?? Or the skid control fuses in the engine bay theres 2 marked as skid control Any help please
  2. Ok thanks for the info and help
  3. I taught that just wanted to be sure thanks
  4. Will a series 1 twinturbo diff fit into a series 2 car Both twinturbo mine has elec hicas and the seller says there an oil feed on the back of diff for hicas I want to weld the spare for drifting and switch them for trackdays Will the diff and casing be a straight swap???
  5. Brembos off a r33 gtr fit straight on, 350z front brembos fit just holes have to be drilled out iv evo 8 front brembos and evo discs on my own needed a bracket to fit them tho got it from america
  6. Ah not to bad so il be doing an oil change before the next day out anyways do u reckon i should go with a higher grade oil 10w 50 maybe as its only used for track use
  7. My car is making a ticking noise after been sitting up since its last trackday probably 8 weeks, i started it up this evening and noticed the noise i didnt drive the car just let it warm up on idle What would be my best bet to fix this? Fluss the engine and change the oil? Drive it and see if it frees them up? Is it doing damage?
  8. Thats grand all i did was run it up to temp then pulled it out the driveway onto the road il put the yellow connector back on so
  9. I wouldnt of done any damage running the csr with it unplugdd would i?
  10. Oh il leave it alone so
  11. I pulled the yellow connector and the fan came on when i started the car ran it up to temp the turned the car off and the fan switched off when car was turned off seems ok to me
  12. Il try that and see thanks
  13. I use my 300 only for trackdays, i have the ac deleted, but the fan is still in place i beleive it will come on if the car goes to overheat is there an easy way to get the fan to run constantly without having to rewire it to a switch? Would like to use it for added cooling better safe than sorry any easy way to do this?
  14. What lenght are the brake lines doing a evo 8 brake swap myself and iam getting brakelines made up just wondering what size in lenght il need
  15. Sent an email to your website regarding theses
  16. Have u an email address
  17. I just picked up my evo 8 calipers iam doing a front brake upgrade the calipers didnt come with brake lines tho they look like they have a banjo fitting my question is iv i buy evo brake lines do they fit the 300zx line
  18. From what iv read up the fronts just need a relocation bracket they can be made up or u can buy them online i found a place online that does the bracket in usa for 100 dollars madracing i thinks the name iam on the phone so cant send link The rears wont fit as far as i know but i read somewhere that 05 sti rear brembos will i have to do more research on it tho
  19. In the middle of doing an evo 8 front swap with the pads discs calipers and brackets its working out at 400 euro i do a lot of track driving tho
  20. What sort of power should it bring at bout 1 bar iv a fmic aftermarket downpipes and decat. Blitz air filter stanard apart from that was going to fit the mines ecu and boost controller Then up boost to 14 or 15 psi
  21. Yea iv a jap import, i emailed mines japan with the numbers so see what they come back with,
  22. Would any rolling road tuner be able to read it i havent fitted it to car cause incase it damages my engine there just the plaque with no 1960 on it and on the bottom a sticker with no.1 on it sorry for spaming ur thread
