300zx TT Mines ECU: How much is it worth?
Hey, I have a spare one. Aany thoughts how much does it worth?
Ahh...I thought ti's something very valuable :wacko:
they are very common so not that valuable, whereas my Mines Ecu for my V8 Soarer sold for 350 quid :D
This was a price I dreamed about :D
I have one of these sitting in the shed didnt know what the tune on it was
Are they all mapped the same?
And if so whats the map on them?
There are about 3 different tunes on the MINES ecu iirc. The only real way of telling which one it is, is to read it to see what the parameters are on it; you need special software and a connector to do that. People like Noel (turbonoz) and John Dixon would be able to do that.
I wouldn't say that any of the Japanese tunes are ideal for UK fuels though. The MINES ECU, as with the one I have which is an IMPUL ECU should come with a ZIF connector in it which means there's no need to de-solder a chipset, or indeed accidentally bend pins on a chip carrier. ZIF connectors are great for quickly swapping out chips without the worry of any damage.
Would any rolling road tuner be able to read it i havent fitted it to car cause incase it damages my engine
there just the plaque with no 1960 on it and on the bottom a sticker with no.1 on it
sorry for spaming ur thread
Yeah or you could mail it to someone who knows what that parameters mean based on what is and is not good for UK engines.
It will be safe enough to run, some of their maps are quite aggressive, but that's generally when you're running higher boost levels.
Yea iv a jap import, i emailed mines japan with the numbers so see what they come back with,
With particularly this one made 338hp on totally stock engine & turbos
Nothing done to it? Stock boost?
Oh yes, right - 16psi.
16psi and it only made that ! ummmm that's not a very good tune
Most of the older more generic chips carried basic maps which only really have an increased rev range, different knock map and dump more fuel. You would expect a bit more power @ 16PSi on stock turbos.
What sort of power should it bring at bout 1 bar
iv a fmic aftermarket downpipes and decat. Blitz air filter stanard apart from that was going to fit the mines ecu and boost controller
Then up boost to 14 or 15 psi
So we tested this Mines Ecu and stock but remapped Ecu on the same TT. The result was 338hp vs 375hp.
