Everything posted by olly300zx
Turbo's
You could very easily disable the pressure the turbos produce and I have done it plenty of times when things have gone wrong, not with me Z but the plan is the same. Disconnect the solenoid valve. You are now running a paltry 6 psi from the wastgates only. buy two fully adjustable wastgates with a weak spring and fully adjust them to the lowest they will possibly go. so the wastegate opens as soon as possitive boost is seen. Voila no positive boost. You don't get the rush of the turbos. or to make it a little easier, just remove the circlip on the wastgate arms, pull the arms off and open the wastgates manually, hold them in the open position. No boost ! The only other way is to remove the turbos fit two manifolds straight to your downpipe, route the oil feeds to the oil returns and the same with the coolant pipes.
help ?
I did know but don't know which one is for the windows and if the passenger and driver has a different fuse each as the passenger window works fine but the drivers doesn't do anything at all ! Cheers
help ?
anyone know where the power window fuses are ? Cheers,
Those who are with Firebond !
yOU LOT OBVIOUSLY HAVE TOO MUCH MONEY TO SPEND AND DON'T CHECK YOUR CREDIT/DEBIT CARDS !!! LOL! i WOULD NEVER LET THAT HAPPEN, OH NO.
clear rear light
Looks good on my bright yellow 200sx but on my silver Z with clear fronts I think clear rears look a whole lot better ! Depends on the colour and look your after. Olly.
clear rear light
$50 all in is for the clear lenses and the tools needed to remove your own lights and remove the inside amber lens and replace with these ! I don't mind doing a bit of work when I'm paying £30 instead of £240 for the same look. lol. In fact these lenses look a little clearer and sparklier(if thats a word). Will look good on my silver z as I have crsytal clear front side/indicators and crystal clear side mount idicators to match. Will post a pic and instructions when done. Olly.
T-piece
I have bought some second hand HKS bovalves and one of them has the fittings from the valve itself. A brass t-piece with one large and one small pipe, the problem is for the other side I don't have the brass t-piece !!! Does anyone have or know where I can get one ? Cheers. Olly.
clear rear light
I got them from need4speed@hlm911.com $50 all in. Will be here soon. Will let you know how I get on fitting them ! I can usually fit anything to anything but if it is difficult and looks poo I'll let you all know. Olly.
clear rear light
I have ordered a set and will let you know when I fit them ! Olly.
Boost Problems after HKS BOV install...>>>
I have jsut purchased second hand hks bov with the hard pipes for my 1991 import. I cannot workout which way around they are supposed to face ! Does anyone have a pic of them installed as this would make it very easy for me ? Thanks a lot. Olly.
Would an NSX temp a Zedder?
the nsx is an awesome car but I still love my z
