im changing my oil and need to know the amount it takes, i have done a search but to know avail.
thanks
You'll deffo find it if you search. I forget the exact amount but its about 3/4 of a bottle I think. Warm your engine for a bit. Turn off and empty the oil into a washing up tub or something. Worth filling up to the minimum level to flush it through and empty that out again. Then throw the new stuff in a bit at a time until it reaches the top level. Remember it takes time for it to settle and you don't want to overfill it as it will pressure your seals.
4.5 litre.....:) engine oil of course ;)
I certainly wouldn't put 4½ litres in.
I'm sure it's either 3.5ltrs or 3.6ltrs.
4.5 litres is tooooo much, I find that for a UK spec TT auto, just under 4 litres fills it to the max on the dipstick.
Put in 3.5 litres, start the engine, then leave it a good 1/2 hour after switching off before checking the level. It really does take a while for the oil to drain back into the sump; then add just under another 1/2 litre.
Richard ;)
The Manual says 3.4 litres with filter change, but you will find just shy of 4 litres to be ideal.
lol i filled 4.5 after wat he said.
not a problem i have other major problems with the box!!!!!
no 1st, 2nd, 3rd, or 4th sliping in each one!!!!
going to cost 1200 quid to put right then will sell the ****er maybe!! spent over 5 grand on it so far!!
dead on 4ltrs inc filter
some knowledge is dangerous :nelson:
Manual conversion parts come up for sale here from time to time and if I can remember rightly they come in at around £700?
Can anyone back me up?
