What noise should a Blitz bov make please help
Has anyone got these fitted ?
I fitted mine last night and not sure if they are working properly. I have backed the adj screw all the way out. One is making a ssssshhhhhh sound and the other sounds like an external wastegate is one of them sticking and if so will wd40 help or what do i do.
Thanks again Guys
Had these fitted, should be silent until u change gear or suddenly back of the throtle, when u do that they should sound like when you open a new bottle of pop..... Tssssssss :)
its not damn one sound like that but the other is not where should i run the vac line from ? currently i have used the old vac line from the re-circ is this good and will a bit of oil do the trick..
thanks again guys i dont know what i would do without this forum (prob walk to work !)
Yes use the standard vacuum line and a bit of WD40 will help if one is sticky. Clean off as much excess as possible as it will become a dust collector - not so bad in winter I guess.
