- Replies 34
- Views 3.2k
- Created
- Last Reply
syed rahman 6 posts
Lamp Shader 3 posts
ChrisC 2 posts
bigmincey 2 posts
I spent more or less the entire afternoon today experimenting with the Zed and it finally worked ! I fitted some Vectra tailgate gas struts to the bonnet of my Zed today and wow what a lift ! It shoots up like a jack in the box ! Now taking this one step further, I removed the bonnet latch & safety mechanism and fitted a heavy duty contact solenoid off an E Class Merc's boot latch mechanism. This took a bit of modding as had to make room for it. I then wired up my alarm to the solenoid and now at the press of a button on my remote the frigging bonnet opens by itself ! Ha ! Ha! Ha! Now my next task is to see if I can close the bonnet with the touch of a button. This is going to take a bit more planning as its a tough on. I was thinking along the lines of a hydraulic system with a electric small pump and release valve mechanism that could be wired up to the alarm. What do you guys think ?
Why did I do it and what benefit is it ? I did it because I was bored today and this automation serves no purpose at all !
PS.
And yes I did have a fail safe system designed into it incase the damn thing opened while I was driving. I added a micro switch to the front of the bonnet and ran it through the aux alarm channel module port (which was originally designed for disabling the alarm when towing etc.) and thus if the car is running or the key is in the on position, the micro switch receives a pulse and prevents the solenoid from being activated.
