hi guys im back lol with a lurvly thread anyway,
got my cambelt fitted yesterday as well as a few belts and some bolts for the tensioner.
when i start up my car i can hear a screach is it the cambelt? it lasts for about 5 seconds.
sometimes as im driving it dioes the same thing.
2 on my stock boost gauge its full load is a 6.5. but on my after market one it says 0.4 psi. whats going on. the car cam with a aftermarket boost gauge but yesterday they fixed the gauge too. :rolleyes:
what does this mean,
Screaching will be the fan belt just will need tightening up (get em to do it)
boost prob could be a number of things.
What does your stock boost gauge read when idling? Is the needle all the way to -14? (it should be, otherwise you've got a leak somewhere).
Are you sure the aftermarket gauge is reading psi not bar? cos 0.4 bar is about 6.5psi
forget the stock gauge, they can be totally inaccurate .
Vijay
Probably just the alternator belt needing tightning after they removed and put it back not tight enough, also it may have a bit of oil or something on it causing it to slip. Its quite easy to tighten, but they should definately do it for you seeing as you've paid them. My front belts (alternator,etc) screech for a few mins when I start up due to them being brittle and needing replacing.
the screech could also be your viscous fan on the way out.
2nd that mine use to moan like the mother in law :smash:
so the screaching is also heard as i rev upto 6000 with no gear. is this the fanbelt?
Hi Indian ZX,
Did you find that white fiesta?
