Oil Advice and Recommendations
Thanks everyone for all the feedback received on the last thread I posted and I hope it was at the least an "eye-opener" for some.
I thought it would be a good idea to keep details of any advice given and a list of recommendations somewhere on this page (hopefully an admin will make it a sticky at some point so that it is easily found).
Looking at my comments so far, these are the ones that I feel belong in here, if you have any others then please contribute or ask futher questions which hopefully will make this an interesting FAQ thread one day.
Quotes so far:
Oilman c/o John Rowland (Silkolene/Fuchs R&D Chemist)
So, the chemistry of “synthetics” is complex and so is the politics!
The economics are very simple. If you like the look of a smart well-marketed can with “synthetic” printed on it, fair enough, it will not cost you a lot; and now you know why this is the case. But, if you drive a high performance car, and you intend to keep it for several years, and maybe do the odd “track day”, then you need a genuine Ester/PAO (Poly Alpha Olefin) synthetic oil, such as PRO S or PRO R. This oil costs more money to buy, because it costs us a lot of money to make, very simply, you always get what you pay for!
Oilman
My opinions are frank but based on facts so I'll apolgise in advance if I upset anyone but I will ALWAYS give you the "best advice", you don't have to take it.
Finally, oil for the 300zx is an interesting one as the recommendations I have had are based around the Manufacturers which is 10w-40 Semi-syn however, depending on driving conditions, the following grades can be considered 10w-40 semi-syn,10w-50 Fully-syn, 5w-40 fully syn and 15w-50 fully syn.
These all have different advantages to the performance of the car depending on how you use the car. Short journeys, long journeys, track days etc....
deve8uk
So how about sugesting something for a zx with minor mods, running approx 10psi boost that is a daily driver and normaly does short trips and only rarely gets booted. And I do mean rarely here.
Oilman
Firstly bear in mind that the car was designed to run on 10w-40 which is the manufacturers recommended oil but as just about all 10w-40's that I know of except for one are semi-synthetics I would go for fully synthetic as it has a higher resistance to thinning down with temperature (a good one that is, not just an excuse for a synthetic with a pretty label) as they stay in grade longer.
Oilman
For short journeys and lots of cold starts, you need an oil that circulates quickly as this is where 70+ percent of the engine wear occurs so rather than using a 10w consider a 5w, its thinner and circulates more easily. 0w is even quicker but may be too thin and you could end up with oil seal leaks.
For faster longer journeys where the engine is operating a high temperatures (hard driving) I would consider a 10w-50 or 10w-60 to give more protection at the top end but you want an oil that has a high resistance to thinning down and "stays in grade" longer. Ester is the best for this (see note below).
For racing and track days, you need an oil that will give more protection still and I would consider a 15w-50 which is a recognised motorsport and racing oil which will protect you almost entirely at the top end.
RichardSmith
What are your views on Millers XFS 5w40 and Shell Helix Ultra 5w40 fully synthetics?
Oilman
Difficult to comment really as I've never stocked Shell or Millers. I would be happy using Shell but based on Millers prices, I wonder about the quality, the first post here may be relevant to their oils but without the data it's difficult to say for sure.
I'll try to speak to some technical bods on monday and see if they have any data or experience of these oils.
Here are some comments so far for kick off.
Simon
  • Replies 188
  • Views 19.9k
  • 3 months later...
  • 1 month later...
  • 1 year later...
change your courier! the nearest depot for the courier you use is about a 72 hour drive from me and 90% of the time im out when the the courier delivers... i was on your site today to order some silko but thought bugger it and paid a few quid extra from a seller on ebay who used royal mail. my postie normally leaves my stuff in a nice place or if not the royal mail pick up points are always local.
just my criticism, not sure if its appropriate for this thread but hopefully seen in a nice light and constructive.
For most people Fed Ex do a much better job than all the other couriers that we've used and if you put a note on the order to leave the oil somewhere, they will. Or they can deliver to you at work, or a friend or relative. No need to let Fed Ex put you off. Believe me, some other 'reputable' couriers are a whole lot worse.
  • 10 months later...
Looking for a recommendation :)
Changing the oil for summer use, currently running 11PSI low boost and 14/15 PSI high boost. Engine has done 80k and doesn't use any oil been on the site and can't make my mind up :/
Any help would be muchly appreciated :D
Hi
I would say a good 5w-40 would probably be the way to go, unless you are getting high (over 125C) oil temps, then a 10w-50 is the best choice.
http://www.opieoils.co.uk/c-656-5w-40.aspx
http://www.opieoils.co.uk/c-659-10w-50.aspx
Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS, Motul 300V, Redline and Gulf Competition.
Tim
  • 4 months later...
Any advice needed ?
Ask us here, will be happy to help :-)
Oilman
check your PM matey :)
but don't worry, just because most dont ask a question, someone might eventually :) we love hearing from you oilman, your the best.
  • 1 month later...
I was thinking of changing the oil and filter in my non-turbo 300ZX.
Halfords say their own 10-40 semi synthetic is ok (for the turbo model).
Will this be ok in my NA? If it's ok for the turbo, it hope it'd be fine for the NA which is running a fairly mild state of tune (around 80bhp/litre).
I always got fancy oil mail ordered in the past but that's the best part of £50 with the filter and I'm skint at the moment.
Hi, thanks that's an interesting suggestion.
I'm really after something I can buy from a shop to avoid delivery cost / time.
  • 3 months later...
ok.always used Castrol 10w60 but i'm thinking to go for something different , reading all these i'm a bit confused now....so what oil is good for a tt running about 14 psi ,with about 100.000 miles on the clock?
:dance:
I would say a good 5w-40 would probably be the way to go, unless you are getting high (over 125C) oil temps, then a 10w-50 is the best choice.*
Tim
Hi
Due to changes on the website, restrictions enforced by Google Shopping and customer confusion, we no longer have the members discount in the same way we used to. All the prices contain the discount now, rather than having seperate members and public prices.
Tim
Fair enough. If you don't ask you don't get.
Decided that I will be going for the Silkolene/now fuchs 10-50 based on your recommendation. This was also a choice oil when I was in the sxoc from what I remember. From what I recall didn't you guys used to do a big barrel of the stuff maybe even some sort of group buy?
Well we can do some sort of group deal, but hold on a day or two and the 10w-50 and other (the new ones) Fuchs Pro oils will be on offer.
Tim
Tim
Sounds good! :thumbup:
ok ok , ive read all this now and.... my brain hurts:wacko:
but i think i get it lol,
so 5w-40 synthetic like the silkolene you sell for example, is a good all rounder for all Zeds generally speaking. standard internals, No serious Mods like....Big turbos, injectors, 20+psi.
Maybe new air filter, cat back, new plugs, remapp.
5w-40?
same for N/A's
lets say someone who had a TT.... had a filter, catback, remapp, running 340-400 Bhp. Still stock inside, stock turbos. 100k ish miles. Everyday driver, drove fairly spirited, the occasional Mad run, flat out runs, brief redline, hard acceleration.
what would you say was the best oil to use for said sort of car/Driver?
lets say a N/A...
air filter, cat back, stage 1 chip, 220-280bhp
same sort of driving.... what would you advise for that?
Im sorry if my questions seem nieve, but its complicated stuff lol, would be really usefull to im sure.. Alot of users and guests if it could be , excuse the nieve....Genrallised a smidge?
eg...
N/A --- Winter- Xw-XX stock
Xw-XX light mods/spirited driving
Summer - Xw-XX
Xw-XX
TT --- Winter- Xw-XX stock
Summer - Xw-XX
Xw-XX
im not sure if thats possible? but i thought id ask.
Apologise again if im being nieve, just good to have a Guru Informed Decision when it comes to oil :thumbup:
Hi
As the most simplified way of recommending an oil, a 5w-40 or 10w-40 is suitable all year round in a standard or lightly modded car used on the road. If you get a really good oil, then that's also suitable for a bit of track use as well.
If there are a few mods and track use, a 10w-50 is a better idea.
To be honest, I'd rather people just asked for their own car, what you see as lightly and heavily modded vary from person to person.
Tim
Was going to get Mobil one from halfords they had semi synthetic only, the guy in there said not to go for fully synthetic as it's an old engine design??? im confused lol
