UK TT Manual Project
In summer 2024 I sold my black TT import that I had put a lot of time and money in to but never really clicked with it. I was expecting to go off and find another car and have fun working on.
But I couldn’t shake the 300ZX bug.
I don’t think there’s another car out there with as much bang for the buck and you just don’t see them around anymore.
So I started looking for a new one. I knew my budget wouldn’t stretch that far so was looking for a project of sorts, but not one that was too far gone.
A lot of the cars I was looking at were too expensive or too far gone.
While putting the feelers out, I got a message from John who had a white, UK Twin Turbo sat in his garage that had been off the road for a while.
One evening a few weeks back I went down to view it, it was about 2 hours from where I live and if I’m honest I thought it could be an option but had another one lined up to view a few days later as I was concerned about how rough it would be.
So, turned on the sellers driveway and it was sat in the garage and looked way better than I expected! It’s not perfect but is a really honest, genuine car. Only 4 owners, has been owned by the current one since 2011 and has barely covered 15k miles since 2004.
Started up on the money, ran smoother than my old one and I was sold!
It has no MOT, needs some TLC and maintenance but I’m very excited to own another one and bring this one back to life!
It arrives tomorrow on a truck, I’ll post more photos, give some more info about it and go over my plans for the car. I’ll use this as a blog to show progress.
Edited by RobHowl
#1. 1993 Twin Turbo Manual LWB in black (2022 - 2024)
#2. 1991 Twin Turbo Manual LWB in white (UK) 2025 -
  • Replies 46
  • Views 4.4k
  • I, very fortunately, live about a kilometre from Torqen who are the JK stockist for Z1. Got myself some replacement pipes. Marinaded the caliper for about a week in penetrant and have been able to rep
  • Well it passed!! I’m so chuffed! The advisories were just rusty springs, and some brake pipes. That can all wait a bit and the main thing is there is no serious issues!! Now on to sorting out some mai
  • Back from the bodyshop today, looks great! Next thing is to get it up on axle stands and replace the reverse switch so the lights work again. I’ll be doing new pads and discs on every corner and will
Brakes bled! A remarkably easy job! Much thanks to AndrewG for the guide on that one. Something I’ve always wanted to do so I’m pleased.
Very nearly messed up big time though!
I wanted to test the brakes were working properly, so had engine running and got wheels spinning BUT I don’t have any wheels on the rear and I hadn’t put the nuts on the threads so the discs started to move! Made a horrible noise, so I stopped quite quickly but have done some minor damage to the discs.
School boy error that but you live and learn!
Should be fine for the MOT, but I will buy some new ones and swap them out to be safe
Well done for giving it a go, things happen but you learn from it and next time will be easier.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
Well it passed!!
Now on to sorting out some maintenance. The cambelt hasn’t been done since 2004 😬
Excellent looking very nice.
2004 BMW Z4 30i
  • 1 month later...
Took the car out for the first proper drive since it passed. Belts haven’t been done since 2004 so didn’t wanna risk driving it much or giving it any heavy revs so just wanted about.
So took it to the garage for a belt service last night via Shell for some fresh V Power and a shot of Redex.
Belts and water pump being done by the garage but when it’s back I’m doing engine oil, filter, air filters, new spark plugs, new gearbox oil and new diff oil too.
Driving last night it was very quick and engine felt great, turbos boosted nicely. Was smoking a bit though and had a whine from gearbox.
I’ve also bought some new PCV valves to install as I imagine the current ones are doing bugger all.
Once it’s serviced I can take it out for a proper drive, get it warm and get the engine working. I’m hopeful that all this servicing and good old fashioned Italian tune up with sort it out.
Failing that it might be trip to Jimmer next winter!
Edited by RobHowl
Good call on the Fluid choices Rob.....😉
You won't need the extra litre of engine oil though - capacity is just under 4L with the filter change. Save that one for topping up, if you ever need to, that is!
They only sold it in 5 litres so to get a 1 litre and a 4 litre was a bit annoying! 😂
  • 3 weeks later...
Belts all done, gearbox and diff oil changed which has helped the noise in my gearbox. Still there but certainly quieter. Will see how it develops.
Changed the oil and filter last night and the air filters too.
When driving back from garage it was good, no smoke. When sat idling, it started to smoke but only seemingly from the drivers side bank and only when it started to warm up.
Hopefully it’s stuck PCV valves. Could be turbo oil seals as well but I’m just hoping not as I’ve already spent a lot on this car 😂
Time to do some driving though I think! I’ll take it out for a long run next week and see how we go. Properly get it up to temperature
New PCV valves in. I didn’t have replacement pipes, and managed to get the old pipe off without destroying it.
Different story on passenger side. Had to cut that one off annoyingly.
Got the new valve in and have ordered new Nissan pipes for both sides.
There was a lot of oil in both pipes so will swap them both out. Will be a few weeks before it arrived though as it’s coming from Japan and they’re on a weeks holiday!
Also replaced my air intake hoses with some lovely looking silicon Mishimoto ones. The old ones were is really good shape still to be fair but the new ones do look tidy!
New spark plugs. The old ones don’t look bad at all to be fair.
  • 3 weeks later...
I’m trying not to feel too despondent right now.
Car felt a bit down on power, seemed to be smoking quite a bit, so booked it in for a compression test.
Ran the car out on Saturday to a Cafe and the smoke did seem to clear up so that was a positive.
Then it went in to the garage and 5 cylinders seemed fine at 145-152, but one cylinder was down 20%. It’s at about 120.
Spoke to Jimmer and he said it definitely is in trouble, the smoke suggesting piston rings and so therefore the engine needs replacing or a rebuild. Both expensive.
So I’ve got a bit of a decision to make, not immediately (hopefully) but wondered what people thought.
  1. Sell it now - I’ll be totally honest about it, wouldn’t want to stitch anyone up. If so, what would it be worth? Difficult to guess I know.
  2. New engine - cheaper but would be a shame to lose the original engine. Am I just being sentimental and I shouldn’t worry about that?
  3. Rebuild - the most expensive option. But would be a nicely built, basically all new engine that should last for a long time and would hopefully retain some value being the original with the car.
I might be clutching at straws but could it potentially be something less expensive? (Valves or something)
Sorry to hear the potentially bad news Rob. Worst case I’d opt for the rebuild if budget permits. Be a real shame to see her go but I fully appreciate the practicalities. Good luck and I’m hoping for a less drastic outcome.
CheerZ
Steve 🙂
'93 UK TT Manual
I’m thinking that too, but it’s going to be difficult to stretch to that.
It would at least mean a very well built and strong engine that I know will last.
Keeps it originality a bit too.
going to keep driving it in the mean time and enjoy it and see what happens. Feels like it’s got a terminal illness! 😂
  • 5 weeks later...
An update!
Cars running so nicely, it’s so smooth, but the smoking problem has persisted and I puts me off driving it if I’m honest. I can bimble around in it but I could do that in a 1.0 Fiesta.
Soooooooooooo I’ve just spent £4k on a parts list provided by Jimmer for a full rebuild.
I’m proper excited.
Will basically be a brand new engine and running a bit more power when it’s done. Nothing mad but it’ll be quick, will have some excellent turbo and intake noises and most importantly will drive nicely as a street car and not leave a blue trail in my wake!!!
I did install a new cheap stereo so I can have Bluetooth! Went retro as it kind of suits the age.IMG_8764.jpeg
Glad to hear that Rob - I was going to recommend either an engine swap or the rebuild....
......Both cheaper than selling it and trying to source another. AND less risk too!
That’s great news Rob. Will be brilliant to get her running better than ever and eliminate the smoking issue. I’m liking the retro head unit as well 😎
'93 UK TT Manual
Yes I thought about it but had already grown quite attached to it and could have easily about another one with the same issue.
It’s a big investment but I know Jimmer will make it sweet as a nut and then it should run nicely for another 35 years! Probably out live me 😂
Thanks mate, it was only a cheap one but I think it looks the part!
