Car of The Year 2018
The 300zx Owners' Club Car of The Year 2018 competition entry thread!!.
Entry is open until the 28th December 2018; after which this thread will be closed and the poll will be posted for everyone to cast their vote!
This is your chance to enter your car into the final competition of 2018 - a trophy and £20 Halfords voucher are up for grabs...…(plus a runner-up trophy)...:yes:
Please use this thread to signify your entry into the competition! I'd ideally like five photographs (no more please, but you can post less) plus a short description of your car.
If you have entered COTY or COTM in previous years, you may use extracts from your last entry - providing your car is broadly still the same.....:biggrin:
I am looking for 6 entrants (but will happily accept more) - we have many, many, fine cars in the club; and we have seen some worthy award winners at Coventry this year, so come on..... What are you waiting for - get your entries in now.....!!!
The competition ENTRY is open to SUBSCRIBED MEMBERS ONLY......... including committee & sub-committee...:wink:
Voting is open to everyone !
And finally, please keep this thread free for competition entries only; all other posts will be deleted....:cool:
TheRealNips
Chris300
AndrewG
nickz32
NemesizX
Bird
t.mogsy
Gaz 300
Black-zed
I will keep this post updated as places are taken; 1 Places left.
PLEASE NOTE: Rules are in line with the previous COTM/COTY competitions, here.........
http://www.300zx.co.uk/forums/showthread.php?169390
Edited by JaiKai
I can put my car for nomination...
These were taken the night before the Eastbourne car show
And here she is with her sister...
Well I thought I’d add my name into the mix this year, so here it is...
This is my modified “94 Uk 300zx. I brought this car a little over a year ago. It had been left for some time without much attention given to it but on the whole was a very strong car.
I’ve spent a considerable amount of time and money bringing this car back up to the level it deserves and most of the work is detailed in my journal, Project UK rewind. The work includes major service on the engine, paint correction, wheels refurbished, new used interior, refurbished rear lights, installing OEM stereo, new boot trims and so on.
A '94 UK spec manual bought in March '98 from Howards Nissan in Weston-super-Mare. The first owner being Nissan UK.
The car is the penultimate RHD car built for the UK market.
The many modifications and enhancements made to the car have always been carried out with the overriding aim of
preserving as much as possible of the original character and identity of one of the best sports cars to come out of Japan.
Modifications made to the car include:
HKS Air Filters and Dual MAFs
Selin Dual MAF Translator
BDE Goose Honk Killer
HKS Exhaust
HKS FCD
HKS EVC 4
HKS Intercoolers and Stillen Intercooler Ducts
NGK Iridium Plugs
Koyo Racing Aluminum Radiator
RPS Max Street Clutch and Segmented Flywheel
Heavy Duty Clutch Fork Kit
Goodridge Stainless Steel Clutch Line
CDF Racing Aluminum Crank Pulley
Eibach Pro-Kit Springs (0.8 inch drop)
Frank de Ruiter Camber Correction Kit
KYB AGX Adjustable Shocks
Nismo bushed Front Upper Links and Front Tension Rods
Stillen Anti-Roll Bars
Carbing Type I Front and Rear Strut Bars
Cusco Brake Master Cylinder Brace
TechnaFit Stainless Steel Brake Lines
AP Racing Front 6 Piston Calipers, 343mm Discs and EBC Bluestuff NDX pads
AP Racing Rear 4 Piston Calipers, 330mm Discs and Ferodo DS2500 pads
Blitz Technospeed Z1 18x8.5J (35mm offset) and 18x9.5J (41mm offset) Wheels
Michelin Pilot Sport 4 245/40 and 275/35 Tyres
Racelogic Traction Control
Audio system:
Empeg MP3 Player Head Unit
JL Audio C3-650 Component Speakers (Front and Rear)
JL Audio 10W1v3-4 Custom Subwoofer
JL Audio HD900/5 - 5 Channel Amplifier
Parts for the next stage of development of the car include:
JWT 530BB Turbos
MSP Exhaust Manifolds
Specialty-Z Super Split Downpipes
Specialty-Z 2.5" Aluminized Steel Test Pipes
Nismo 740cc Injectors (with JWT adapter kit)
Robert Bastian 62mm Billet Throttle Bodies
AshSpec Massives 2.5'' SMICs
AshSpec 2.5'' SMIC Piping Kit
AshSpec 2.5" Planar Inlet Pipe Kit
As people seem to be self nominating, I shall throw my cap in and offer my 1995 Series 4 Twin Turbo 2+2 that I have owned for neigh on 11 years. It has undergone quite a few changes and a lot of work over the last few years, all of which has been documented in my build thread https://www.300zx.co.uk/forums/showthread.php?188495-My-daughter-calls-it-Toothless-the-Dragon-My-%9195-TT-Z
The spec is as follows:
Engine/Powertrain/Drivetrain
88mm CP Pistons
Saenz Forged Con Rods
King XP main and big end bearings
EP Racing Thermal Barrier Piston Coating
EP Racing High Performance Bearing Coating
EP Racing Billet Crankshaft Cap kit
EP Racing High Capacity baffled Sump v2
ARP main crank and head studs
EP Racing modified crank
EP Racing modified oil pump
Ross Performance dampened crank pulley with 12 tooth Timing Ring and Hall Effect sensor
Ross Performance Camshaft Trigger Kit (CAS Elimination kit)
EP Racing “Street” profile CNC Head Port
SuperTech 0.5mm valves
SuperTech dual coil valve springs and titanium spring retainers
BDE v2 intake VTC pulleys
Power Enterprises Kevlar timing belt
EP Racing belt tensioner
AMS exhaust manifolds
Z1 GT525 turbos
AMS 3in expansion down pipes, full 3in exhaust system
WinFactory top feed fuel rail with Injector Dynamics 1050x (1065cc) injectors
Z1 SMIC modified with 2.5in flanges
Setrab 19 row oil cooler
AMS alternator/power steering pulleys
All built by EP Racing
CZP 2.5in IC piping
HKS SSQV4 BOV’s
Koyo radiator
Haltech Platinum Pro Stand-alone ECU, with 3 bar map sensor, IAT sensor, 3 port boost solenoid, fuel pressure sensor, Bosch wideband O2 sensors and Haltech WBC2 controller
Turbosmart FPR2000 fuel pressure regulator
Full -8 fuel line from tank to rail and return with Torques AN fittings
Custom Billet fuel tank lid with AN fittings and custom pump holder
Walbro 485 fuel pump
RPS Streetmax Clutch
SZ segmented flywheel
CZP 1 piece clutch line
Chassis
Meister R Zeta R coil overs
Nismo and Tein from suspension area
Whiteline Rear suspension arms
Evo X brembo front callipers with DBA5000 2 piece discs
Varsstoen ES2 18x9.5J ET22 front 18x10.5J ET30 Rear (Michelin Pilot Sport 2 255/35 and 295/30)
Body
Stillen Type iii splitter
TwinZ fog light ducts
Smoothed stone guard on sills and Rear bumper
WinFactory CSL-R spoiler
All window seals and trim pieces renewed
Carbon Fibre windscreen scuttle panels
Interior
Alpine ICE
Defi gauges
OMP dishes steering wheel
Well i guess its worth a shot and its the taking part that counts huh lol..
So, ill put my old girl nostrils up too as shes had a good makeover this year.20181130_152406.jpg
Edited by NemesizX
Here's my tt manual. I bought this as a shell 5 years ago so there's been plenty of work done. The most recent being a full interior (award winning) completed by Mondo, black leather with alcantara centres & silver stitching. Other upgrades include one piece prop, 99 spec inserts, altia door sills, stillen lip, twinz rear diffuser, meister coilovers & lots more that I've forgotten.
Can I enter mine please. Home driveway custom paint job lolb87e9db54212112d1bd745bc3b85e746.jpg73bc839058a571314cb65e76f9d51cec.jpg026645719b9895775b6c7ffb8be43025.jpg208169059b54eb5bdf80a638028ada63.jpg1770b07625d7c707dbcafb6602b0774b.jpg95b91dbdfddef42a97fac8743caa0984.jpg4b63cd69d1d14de216029fa50a74ef12.jpg71e8ad51d28e0ebfa4104b4e5be5da72.jpg95dc1c5be94cea90b8e97c77039d0840.jpg
Membership No 0780
INSURANCE GOOFA
i's like to put mine forward, just to see how it fairs, mine definitely isn't show worthy but very much a work in progress and has improved considerably over the last year or 2. still a lot to do but it's getting there slowly IMG_0646.jpg
