April 28, 20188 yr I've bought another Gloria for parts but the cambelt had slipped a tooth at idle. Is the engine a tolerance engine with clearance between the piston & valves or will it more than likely have bent a valve? What other damage could it have done?
April 28, 20188 yr If it's one tooth you should be alright, but They are interference so probably bent a valve if many more than 1. Mark off the head and pistons as being unusable just in case, but they might be fine. Edited April 28, 20188 yr by Alic
