New Horn - Whats the best ?
OEM Bosch horns as fitted to late Primeras if you want to continue using a single terminal; if you're ok adding another terminal (earth), then PIAA dual tones are about the best quality and sound you're going to get.
The single terminal OEM Bosch dual tone horns are fitted to many different cars and have the same part number. They can normally be had used on eBay for around ยฃ10 and are infinitely better than the originals! Mine came off a 2010 Jeep Grand Cherokee and looked new (I think theyโ€™re located out of the elements!), but itโ€™s probably best to search by part number (which I canโ€™t remember off hand).
Failing that, Andrew has the Hella Supertones fitted and these things are loud and manly! At the NEC we had a โ€œhorn offโ€ and it was a bit like the Hulk vs Dangermouse!
I got these also on Richards recommendation, havenโ€™t heard them yet though:thumbup1:
