My daughter calls it Toothless the Dragon: My ‘95 TT Z
As with most projects and rebuilds, they all start in the same place, mine was no different. However, this isn’t truely the start of my forever ongoing Z project. I’ve owned this car (my second Z) since 2008 when I purchased it from a former member. For the first 5 or 6 years I did the usual mods with suspension parts and basic bolt ons. For reasons unknown, whilst running stock boost, piston 5 cracked a ring land during a track day at Castle Coombe. A forged build and a remap later all was well until a sunny October’s day 2013 at Bruntingthorpe killed that engine with what at the time was a suspected head gasket failure at 181mph..... And this is where I shall start my journal.
The Z was stored off the road from Oct 2013 until March 2015. I’d had a major knee operation at the beginning of 2015 which meant I was going to be off work for 6 months. I’d saved up enough to start thinking about a parts list to rebuild her and frankly, after a couple of months of staring at the same 4 walls, I was going stir crazy! I employed the help of a good friend and decided to pull the engine and see what was what.... just a head gasket my arse!
March 2015
Problem 1: It turns out stainless steel, exhaust wraps and condensation don’t mix well
Before I’d even got the engine out, a new set of downpipes was added to this list. These AMS items were only 2 years old, so I was far from impressed! I contacted the retailer and after a bit of tooing and froing I secured myself a set of replacements for free... how long they will last, only time will tell!
  • Replies 683
  • Views 108.9k
  • Hey all.   well I’m happy to say my engine saga is now pretty much behind me and I’m free to move on with my car!   So, what does the future hold…. Well I’ve pretty much got to start
  • After a bit of testing with various polishes and pads, we found that the Lake Country wool pads with Scholl Concepts S3+ followed by S20 Black on a meguairs polishing pad, then finished with S30+ on a
  • Over the last few months, a friend of mine and I have been undertaking the most thorough detailing work I’ve ever undertaken. Just over 70 hours of work have gone into my car, from 2500 and 3000g
Pistons and rods installed. Just waiting on a set of STDX King rod bearings to make some adjustments to my big end bearing clearances…. Unsurprisingly, the STD size bearings EPR used produced 0.0017” clearance not the 0.0035” quoted in the build sheet. Targetting 0.0025” for this build. Also reinstalled the @brettdempseyengineering oil tree. Oh and I will never use a ratchet piston ring compressor ever again, these ring compression sleeves are SOOOOO much easier to use!!
  • 4 weeks later...
Bottom end is now complete.
Hopefully get it back to my unit soon so I can start work on the heads and get the long block complete
Goodies courtesy of CZP and SZ
2.5” turbo intake kit
BDE low profile engine mounts
CZP replacement lower rad hose, clutch booster hose and intake valve cover crush washers
Gates Kevlar belt
Upper plenum gasket
New turbos have already been ordered, hopefully be here before the end of the month
Bit of a backward step this yesterday.
Got the short block back to my unit and installed the BDE engine mounts, water pump etc. After spending a ridiculous amount of time clearing the crank timing gear (wasn’t smooth going on the crank snout) I span her over to start working out true TDC, when I felt a gear like notchyness at a certain point in rotation. Given it was smooth as silk when I span it over prior to pump install, I instantly thought oil pump. Removed the sump and pump, and all spins over smoothly again.
Pump was a replacement sent by EPR immediately after its failure, and clearly wasn’t new as it had very little assembly lube inside it. Having taken it apart I can see it galling inside the pump on the leading edge of the small gear, so in the bin that goes and a new pump on order….. dear lord they’ve got expensive!!
Edited by nickz32
More tinkering yesterday.
Spent some time finding true TDC ready for timing the cams up.
New oil pump arrived courtesy of @conceptzperformance (brilliant service as always) and got the cylinder heads on.
Next job will be set up cam timing and measure piston to valve clearance. Once complete I can order the new set of head gaskets and start the final assembly
More progress. Verifying the cam timing and found the exhaust cams were off by 3 degrees. Surprised that the intake cams were spot on where the should be considering the new block and heads being skimmed.
Next job is adjust the cam timing to get it to spec, then pull the heads off and play doh the pistons and check Piston to Valve clearance. Will also advance the intake cams 10deg to simulate VTC activation and make sure everything has plenty of room
Haven’t messed with Play Doh for probably 40 years 😅. Cam timing has been finalised, so was time to check piston to valve clearance. Turns out I’ve got LOADS. 4.4mm on intake and 4.9mm on exhaust. Finally day of tinkering complete before the family holiday to Sicily. Straight back to it when I’m back, and hopefully take delivery of my new Singapore swirly boys
