So my paint job has again reacted as soon as it got hotter, again. Crazing/cracking...the only option is to strip to metal an try again, for which I no longer have facilities. That's not the issue though.
As mentioned before I have a running problem, I've pulled codes 34 (knock sensor) and 12, MAF (but that should be because I had it disconnected). Even if there is a knock sensor issue, would this cause the engine to stumble and stall?
The car runs great until I connect the confirmed 'good' MAF. So this suggests pump, injectors and coils are fine. Maybe an air leak then...
The engine used to run fine 5 years ago, and so can't be a major issue, gunk maybe. Although history is limited, the engine should have only done 64,000 miles.
In a nutshell, after 5 years I've had enough. Despite feeling a bond with the car I've rebuilt over the past 5 years, and not being the kind of person who gives up, I just feel that maybe I need to move on...
If the paint looked like it did when I first painted (which was amazing!), then at least I'd know I had a great looking car after fixing the running problem....but I wont now.
I have some time off work soon, and the plan was to pull off the plenum, replace with a clean shot blasted one, checking for any air leaks. I have the gaskets (except the IACV one). I was going to clean out the IACV, just seal it with gasket sealant. I have gaskets for the plenum and throttle bodies. Personally I don't believe there is an air leak. I did delete the EGR when the engine was out, but the plenum holes were sealed...it can't be that, but it's the only thing that's changed since the engine last ran.
I just fear this is the end. I just can't do it anymore. Maybe there is a time to just give up, despite everything you've given. I need to move on....
