Which series is best?
This could be a very obvious question but which series of zed is the best mechanically electrically and best for the user? Excluding the 1999 spec.
Series 4s probably, updated PTU, injectors, climate control, interior materials and generally less old. off the top of my head.
but the series 1s have nicer carpets and I prefer the non airbag wheels of the s1
Thanks thought that would probably be the case but just wanted to be sure. Definitely agree about the steering wheel though!
Evolution is too subtle to really matter I think - series 6 probably had the biggest changes, but still mainly small improvements as time went on. I think losing VVT is the only significant disadvantage of 5/6.
Later cars had
1 Less insulation
2 Thinner carpets
3 Missing rear blind
4 Less underseal
5 No vvt
6 engine components not enamel coated
7 Lower spec ac / heating controls
8 Thinner cloth on trim and seats
9 Nasty 16 bit ecu
10 No turbo gauge
New spec choice from S R and 99 spec spoilers, bumpers, side skirts etc. Recaro seats, xenon headlamps...... mid range series 4 are about the best of the lot for specification, but seen way to many 98 + zeds not in good order underneath, almost they used different metal?
Jeff
I don't find Zeb has a "significant" disadvantage without the VVT either to be honest. acceleration is very similar to my white zed (s2)
Later cars had
1 Less insulation
2 Thinner carpets
4 Less underseal
5 No vvt
9 Nasty 16 bit ecu
10 No turbo gauge
Some of those depend on trim level though. You could get a final edition Z with all of the luxury items, like leather seats and automatic climate control. It just happens that the "sportier" trim levels appear to have sold better.
Turbo gauge came back also, weird that they dropped in for a short period.
One that has been looked after and cherished irrespective of age.
Absolutely!
Spec-wise though, I'd say 91-94 irrespective of series. Better specification and materials. Series 2-4 ideally as you dispense with the tweed. Avoid 89/90 cars unless they've had the heads replaced or re-engineered (soft valves on early engine numbers).
Edited by Funkysi
Later cars had
1 Less insulation
2 Thinner carpets
4 Less underseal
5 No vvt
9 Nasty 16 bit ecu
10 No turbo gauge
Jeff
You answered your own question there. ;)
The thickness of underseal and coverage looks substantially less on late94/95+ cars from what I've seen.
Edited by Funkysi
Absolutely!
I queried this and Stephen told me this was only on certain engines? and that most of the soft valve cars would not have made it this far.
Just for my own clarification :thumbup1:
89 and 90 being 'certain engines'. They made it all the way up to a certain engine number which I can't remember the figure, these were found in all 89 cars and 90 cars for most of that model year. There are still engines out there that are running early heads with original valves. If you don't know the history and engine number is low enough, I'd avoid.
Thanks for all the help now just to find the a little more money and the right car.
Later cars had
1 Less insulation
2 Thinner carpets
4 Less underseal
5 No vvt
9 Nasty 16 bit ecu
10 No turbo gauge
Jeff
Think of the weight saving though :biggrin:
Owned two series 4 Zeds and I think they are great.
Few enhancements here and there the average Joe wouldn't notice but some of the changes
Like loss of the boost gauge can just be fitted as oem because the cable looms are there.
For somebody like myself doing a full rebuild there a great base to work from.
If you can bloody find one!!
Didn't think it was that hard, I own two spares and many carcuses
For spare parts.
Just need to know where to look and grab a bargain.
I haven't been able to find a series 3 boost gauge, not that I've been looking for months and months mind
