Project Dittohead Red
Right, thought I'd start this. As some of you may know my cars a bit broken at present and I have a pile of parts ready to fit that gets bigger without it making its way to the car.
So lets start with what's up with the engine. Myself and gaz pulled the engine about two winters ago now, as one of the turbo's had failed. Compression was tested at this time with a very even 170psi across the board. Pulling it all apart we found a multitude of issues, egr hanging off causing an exhaust leak old sockets rolling about etc etc. We took that time to replace every damn crusty water and vac pipe and delete just about anything I considered a waste of space.
Water plenum bypass,
EGR,
AIV,
PRV,
Cruise control,
Aircon,
Think that's all. The turbos were rebuild by myself and for the first 50-100 miles things were bob on and I didn't give it too much stick. The first couple of pulls it detonated, new plugs, reduced the issue but it still did it a bit. Changed to a smaller gap and great the det was gone. The car was pulling very well at this point with virtually no lag and was dyno'd at 289hp bone stock, no extra boost no chip. Not bad for an old auto engine. Sadly it had started to smoke on over run, I assumed id cocked up one of the turbos during the rebuild. So I had been putting it off for months, well actually years now to pay out for brand new turbos. Anyways as the tax ran out I thought id do some more inspecting as the symptoms just didn't fit the pattern of failed turbos. The first thing I found was that lovely even compression was no more, cyl had a rather lame 115psi. Cue further inspection to work out exactly what block I had, manual/auto etc I assumed it was auto. That's when I found this...
That head casting reads R-10Y, wtf is that I thought. It's supposed to read 40P this was one of those penny drop moments. The piston crown sealed that moment of realisation and many dots connected.
That's right its an NA, 30p pistons are NA and 30p1 are TT defiantly no 1 on that code. Turns out r-10y is the later spec NA head aswell, so yeas 100% an NA block. Now this engine was fitted by a garage 4 years ago a few months into my ownership and we wont go into that too much but it wasn't a great experience and it transpires it was worse than I first thought. Anyway whilst they refused to reimburse me for that error, a good will gesture was sent out to me in the post of a few quid.
So a replacement engine is going to be sourced and fitted this winter. More of that and what's happening to the current late spec NA block.
So now more about that shelf of parts. I purchased last winter a full rear subframe assembly off Jaffa, the one off his time attack car. Loads of goodies already polybushed to death etc. So I stripped it down to bare metal and started painting it all with a few coats of lovely hammerite. This is how it stands at present;
So this winters aims are.
Remove front and rear bumpers, re underseal all of that and rip out and guff.
Delete HICAS system
Reloacte PS reservoir and fusebox
Switch over all suspension to new units from the shelf
Fit 354mm diameter brembos
Change engine out and preform various mods
It sounds like a lot, but hey winter is along time. Don't expect it to be coming through thick and fast. Im lazy haha
  • Replies 421
  • Views 37.2k
  • After a bit of faff about with the battery which was a Covid victim we got to the MOT station. Happy to report a pass. The guy was pretty intense on it and I picked up some minors. He was fair th
  • So after a very long, dry, safe and cosy sleep since the beginning of this global pandemic she’s waiting for an MOT.
  • Just to update this. Ive now mot’d the 32.   I’ve been and looked at a couple of Z34s and driven one this week which had a remap and an exhaust. About 30k on the clocks and clean. I was quite
Oh I rolled the arches as well so I can run the proper camber at the rear again.
Yup they are all in there :) looking swish.
I think I just realised a mistake. The rear calipers the bleed nipple is facing down. The bleed point is fairly central but I think they should be the other way up. Can I just unbolt and flip them for the bleeding process?
Phew, sorted. I have to admit though there's still not that rock solid progressive feel you get on a new car.
Well I'm at the mot place. Few things noted on the mile drive here...firstly there's still an issue with the brakes that needs attention. The alignment settings are as suspected silly. I need way less negative camber at the rear and more low at the front. It looks a touch comical at present.
It's a bit like that but the opposite at the rear. The front I could get my fist in the arch gap.
Well done, you must feel pleased with all the work you put in
Sadly there's some bad news though. There's a tiny issue with one of the new calipers meaning I can't sustain brake pressure. They get progressively worse over time. So essentially I need to sort that before I can drive it. Failed on a minior detail the day before. Gutted doesn't cover it.
Il get it sorted this week, just miffed as I really wanted to get out on track.
Basically one of the bleed nipples sheared off on the caliper. Common issue with these by the sounds of it. So I pain staking lay drilled out the thread half a mm at a time. Sadly it appears I've nicked the caliper body and the nipple no longer seals properly. That's my leak. Gaz popped over this evening and we tried to rectify the spongey brakes, at which point he noticed this fault. Any ideas greatly recived.
Sadly japfest is now out. Despite my best efforts I fell at the final hurdle today. With the wedding a meer two weeks away now I simply cannot justify driving the other halfs kia to castle combe in the early hours. To walk round the event and then leave early when an increasing list of stuff builds up here. So sadly I'm out :(
Rest assured though my zed will be on the road over the next week or so once I get round this pesky issue.
Gutted for you mate, after all the work and effort you put in.
CHIN UP! Always look on the bright side ...At least the brakes didn't fail when you were lashing down a racetrack!!
That's the exact conclusion we came to. It's a serious buisness stopping, not much room for error. So in a way I'm glad we found it and we found it before it caused a problem beyond a spongey peddle.
Drivers side brembo front. The last one to bleed which helps with the illusion that it's working to start with.
