Climate control faults.
- Replies 50
- Views 5k
- Created
- Last Reply
Stephen 33 posts
AndrewG 4 posts
hellraiser 3 posts
jimmer 2 posts
I'm a bit lost were to start here. So I'll describe the faults and symptoms and what I've got. I've tried using the diagnostic on the pod which revealed not a lot and the instructions were incredibly poorly written and didn't actually seem to corrolate with what was infront of me.
I've got the early didgital climate control, with the high & low settings on the side. The car is an 89/90 model JDM car. The air con compressor and rad are removed. Some of the fault predates this, the other has occurred a few years after those mods so it's not in my opinion the likely culprit.
The two faults I have are as follows;
When the fan is on it blows hot air, regardless of the set temperature. This making the cabins touch cosy as the heat exchanger is permanently hot. Using the manual activation of the actuator in the diagnostic program allows cool air to be blown. Returning to normal operation the heat is back.
The fan blower itself now no longer works. This started a few weeks back. No air is switched on regardless of the settings.
I've read a few threads on the subject but now found a golden goose and I really need some pointers at least what can I test and isolate this pesky issue. I've had a look at the fuses in the drivers footwell and none are blown.
