Will r34 gtr brembos fit?
Someone's parting out an r34 gtr here and I'm wondering if the brakes would fit my z32? My current setup is 350z track edition rotors with the czp caliper adapters. I'm thinking just the calipers, I think the rotors are about the same size as the 350z track edition?
Think they're a straightforward bolt on caliper bud, I await the experts to say otherwise but think you should be ok:thumbup1: You might have to widen the holes and you have to run 17" wheels or larger:thumbup:
Edited by Richie K
I thought the R33 was a direct fit and the R34 needed an adaptor of sorts.
Hi Lee, I think it was the R34 calipers came with 14mm bolts instead of the usual 12mm ones that are on the R32-33 and 300zx. You just have to drill the mounting points out to 14mm ??
I found some info via Google that seems to support that. So you only drill out the hole to 14mm and use the matching rotor and you're good to go?
Yes, but I'm not sure that 350z rotors will work with the Skyline Brembos, I think the offset is different.
I think your right there. From memory there's a small offset difference, few mm. I seem to remember someone using a pair of washers to adjust the offset on the calipers to use 350 dis s which are cheaper on the skyline calipers.
