JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 132.9k
  • And they have arrived !
For the cost it won't be something I'll be replacing at the moment.
I'll touch it up later with some paint if needed.
It’s not something that needs replacing for aesthetics, there’s nothing wrong with the way it looks. It’s more from a service point of view as that dampener has carried fuel for over 20 years now! It looks like your FPR has been replaced though?
It's more PM than aesthetics:
http://www.twinturbo.net/nissan/300zx/forums/general/view/2610744/Here-is-how-it-works.html
What a productive day today has been, strangely great weather too.
Engine is back in, harness wired up, radiator and water pipes hooked up.
Clutch booster system back in and connected; that was a bugger to fix.
Tomorrow i'll jack her up and prepare to fit the clutch, flywheel, prop and exhaust.
Might be close to starting her up in a few days.
I've got a feeling that my bonnet WON'T be getting opened at the NEC! :scared:
mine looked like a barn find under the bonnet last year when Jimmer visited the stand and wanted to have a look :lol:
my car always seems to have straw or feathers stuck on it somewhere whenever i turn up at a meet
ok, before I tighten this bolt and forget about it !
Should there be copper washers above and below the bolt ?
[ATTACH=CONFIG]114782[/ATTACH]
you will not tighten that bolt and forget about it if you don't fit the washers Lee... you will soon get a reminder
Few things I need to get today, and I've added copper washers to my list.
Need to do all the oils and fill up the radiator with distilled water too.
Luckily I have a trade card for Halfords.
My list is getting bigger every time I think about it :
Engine oil.
Brake fluid.
Distilled water.
Coolant additive.
Copper Washers.
VAC pipe.
Coil Pack Bolts.
