JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 133.9k
  • And they have arrived !
Now I may have an issue, can't seem to get this ECU to power up.
The new engine is still on the stand so I know the wiring loom of the engine isn't fully connected but I have properly grounded
parts of the looms that need to be grounded but i'm getting nothing from the ecu and my laptop wont connect to it either.
Am I missing something - apart from an engine.
All I want to do at this point is ensure the ecu works and that the software unlock code I've been given works properly.
Maybe I'm getting ahead of myself on this.
As the engine isn't even fitted yet so to get power to everything I've grounded all the looms and hooked
up the ground for the battery to the chassis too.
I've likely missed a ground somewhere.
Engine should be fitted this weekend so hopefully it will power up.
Why don't you power up the old Lee, see if you can get that going first.
Fair play to you for taking on the task of finishing and fitting the engine Lee:punk: Won’t be long now :thumbup1:
