300ZX TT 1990 UK MANUAL - For Sale
After almost 9yrs of ownership and unparalleled enjoyment of my Zed, I’m finally calling time. It wasn’t an easy decision but I feel the time is right to let someone else take it on and enjoy it as much as I have. I’ve learned a hell of a lot during my time with it and have numerous friends and stories as a result of owning it.
This is one of the original SE Nissan 300zx’s and even featured in their parts catalogue (scanned copies provided with sale). The car has also appeared in a Max Power DVD as a feature car (‘Max Power: Hardcore Tarmac Terrorists’) whilst owned by a previous owner.
The car is in very good mechanical condition with Jimmer at PowerZed giving it the all clear following a visual inspection and a check on ConZult. All mechanical work worth mention has been completed by PowerZed. All bodywork since I’ve owned it has been carried out by Custom Exotics. A lot of money and time has been spent on the car, some details below with more available on request. I have full records of all work carried out with all receipts, etc.
The car has been mapped on a dyno and has a proven 547fwhp at 19psi with 508ft lbs. I’ve listed as much as I can below. More details are available on request.
MOT valid til 25 Jan 2017
Tax is no longer transferrable - new owner will need to tax to drive away
Mileage 149k miles (full engine rebuild at 132k miles)
Engine - PowerZed Build done at approx 132k miles so new engine has only covered 17k miles
87.5 Wiseco pistons
Cometic head gaskets
ACL crank bearings
Z1 GT535r hybrid turbos and divorces downpipes
Nismo 555c injectors
NGK Platinum spark plugs
AMS High Flow cast exhaust manifolds
New Rhd EFI engine loom
Plenum stripped and painted in Dark Candy Apple Red
…more details available on request
Red Autobahn88 siicone intake hoses
Blitz DSBC Boost Controller
SE stainless steel exhaust system
Series 2 PTU
K&N Hi-Flow Air Filter
PACE Side-mount intercoolers & silicone hoses
Aluminium lower radiator hose
Custom Osty aluminium with CF effect slam panels - 3pc
Duracell DA70 Advanced car battery
Drivetrain & Cooling
Automatic to Manual conversion at same time as engine rebuilt (132k miles)
RPS Max Street Clutch (
Z1 Lightened Flywheel
Suspension
MeisterR Zeta-R Coilovers
Driftworks HICAS Elimination
Cyberspeeds Front & Rear Camber Arms
Cyberspeeds Rear Traction Rods
Cyberspeeds Front Tension Rod
Stillen front and rear sway bars
Brakes & Wheels
R33 Brembo front and rear brake caliper upgrade - custom red with black lettering
EBC Red Stuff brake pads
Front SE AP 330mm brake disc upgrade
Stainless steel braided brake hoses
18” Antera 143 alloy wheels
Pirelli P-Zero tyres on rear (
Continental ContiSport Contact 3 tyres on front
H&R 15mm spacers on rear
Bodywork
Silvia Engineering bodykit consisting of SE Monza nose cone, SE Monza front bumper, SE Monza rear bumper, SE Monza vented bonnet abd SE Monza rear wing
Silvia Engineering custom brake ducting from under front bumper to front brakes
Car.Mad sideskirts
Sidelights relocated and custom Car.Mad fog light ducts fitted
99 Spec Rear Light conversion
Smoked side indicators
Front headlight inserts painted chrome black
Roof bars and wing mirror plates painted gloss black
S2 electric folding & heated wing mirrors
Full body underseal
Security
Toad Ai606i Interactive Alarm & Immobiliser
Interior
LED dash and pod conversion
S2 heater pod and ECU
Option gauges and 3-gauge pillar pod - Oil pressure, Water Temp, Boost
Series 2 grey alcantara door and console trims (replacing original Series 1 grey tweed)
SkinZ sound deadening of doors and under rear bench
ICE Install - note that this is incomplete
Already fitted and included in the sale:
Infinity Kappa 60.2cs speakers x 2 fitting in custom tweeter housings
Infinity Kappa 652.1cs speakers x 2 fitted in front doors (6.5")
Infinity Kappa 52.1i speakers x 2 fitted in rear (5.25")
Sony XM-C2000 Stereo Power Amplifier - fitted in custom box in boot underfloor
Custom fasica panel to house 7" android tablet
High quality cabling and fuses used throughout
I was intending on installing a 7” Android tablet connected to a usb hub for a myriad of applications. I have all the component parts and am happy to include them all in the sale (exc the tablet) with my plans on how to complete if the buyer is interested in finishing this off themselves
I also have the sub to go with the setup - this will need a sub box. Sub is not currently included in the sale but happy to discuss if it’s of interest.
Infinity Kappa 100.1se subwoofer (10")
Other Parts
Original car jack, wrench and chocks in the original mouldings
Original targa bags
Spare Parts
Also included in the sale but not currently fitted:
AMS short shifter kit
Full lock set with replica titanium keys
Titanium dash rings
Spare drivers side targa panel
Lots of spare OEM screws, clips and
1 x uncut replica titanium key
2 x uncut spare metal keys (valet)
Several SKinZ sound deadening panels
Spare Exide EA755 car battery
I’m sure there are other bits and pieces which will surface as I start clearing out which I will include in the sale as well
Bad points
With full disclosure in mind, the following points are the ones that I am currently aware of. None are insurmountable but worth mentioning:
Although the seats are original and date back to 1990 they are in a reasonably good condition and are still quite supportive. The exception to this is the driver’s side bolster which has a large hole in it through which the frame is showing. Should be a fairly straightforward part to switch out with a good condition spare/breaker
The fibreglass bodywork has a few areas that need attention - this is largely from grounding on raised surfaces (speed bumps etc)
The aftermarket oil pressure gauge is not working - this is likely just down to the aftermarket sender having failed. The stock gauge functions correctly
The passenger side window needs adjusting so that it sits more flush with the targa rubber. At the moment it can let in some water in a downpour however I keep the car garaged and rarely drive it in the rain so it hasn’t been a priority for me
Think that about covers it. I'd love for it to go to someone from the club who will pick up where I've left of and keep it going for years to come. Any questions, please ask / PM me.
Edited by sumshiftyguy
  • Replies 48
  • Views 2.7k
have not got a clue how to do stuff like that
I assume this is LWB?
It is indeed
Sent from my HTC One_M8 using Tapatalk
  • 3 weeks later...
Still for sale and discovered that it was also a feature car in Japanese Performance Mar/Apr 2000! Pics for interest...
Good luck with the sale buddy and I hope you enjoy any future motoring as much as you've enjoyed the Z
Hi Vig,
Great to see all the pictures and history of this car that has been so well looked after. Would love take take it off you but funds don't quite meet what you're currently asking for it. If you're open to a serious offer let me know. I would come down to have a chat about it etc as you said it would be great car to keep in the club. Good luck.
Hi mate, I am open to serious offers so happy to discuss further. I can't send you a pm as you're only registered but if you can see my number on the ad at the top, why don't you drop me a message and we'll go from there?
Hi guess as im only a registered member I can't see the details if you want to drop me an email with your contact details my email goatboyadam@hotmail.com I am looking for a keeper to enjoy for as long as I can but would love to chat about the car. Adam
Still up for sale - lowering price to £8k ono....get in touch if you might be interested. Would rather it go to an enthusiast from the club!
SE Nissan is an acronym for Silvia Engineering. A Z specialist in the late 90s - mid 2000s headed by Pete Rosenburg. They developed a number of styling accessories as well as engine reworks. Well known by old-skool Z-heads, but not so much by you younger crowd! lol
I first learnt about SE from Gran Turismo 2! or was it 3? one of them...
hey its jay from costco today, awesome car good luck selling it man!
  • 1 month later...
Bump - still for sale!
Anyone any idea how I amend the details at the top of the listing?? Price, etc?
It might be worth trying to find a better driver's seat as the one that's in really ruins the overall finish of the car!
A fair point but I'm offering discounts to cover. Plus it's only the rich bolster that needs replacing as the rest of the seat is still in fairly good shape and in line with the rest of the interior.
In any case - looking to offer more discounts to get it sold now Just need to find a way to edit the listing.
I get that. But you're asking serious top-end money for a car which has, at first glance, a tatty interior - irrespective of how good the rest of the cabin might look, the first thing people will notice is the ruined driver's seat.
It may have superb mechanicals and a top engine build, but unfortunately that seat spoils the whole appearance of the car.
Bump - and price adjusted at Vig's request.....
....Come on folks - this is a great Zed and now it's a steal at the price Vig has lowered it to....
GLWS mate:cover:
  • 3 weeks later...
And.............SOLD!
Is it still in the club Vig?
It isn't no but I have directed the new owner to the club.
