my build thread
time to start a thread now so wil have a go loads of pics to up load so will start with some parts i have
IMG-20130714-00443.jpg the car 100% uk stock when i got it ,
  • Replies 442
  • Views 33.7k
new bumper support and clips all so rolled one side of the car for the wider wheels got one side done but there is a bit if rust on the drivers side so have to get a new arch kit welded in this week you can see how much i rolled here to kit the big wheels in IMG_4560.jpg
no roller pic
rolled arch
IMG_4565.jpg you can really see in the pic but in real life look very good
I used the same bit of kit. However I didn't flare mine just rolled the lip flat so I know it won't slice into the tyre wall.
needed to flair it due to the wheel size it looks really good in real life
so i rolled the left side arch no problem nice i dry zero rust. but the driver side had a bit of rust on the very edge so i couldnt role it so i got a new panel. i have to say the panel fit it spot in on very good indeed so that will be getting welded in this week before paint IMG_4573.jpg
test fit of bigger rear discs
nice selection of stainless steel bolts ready for when the manfold comes off for the delete and over haul. not sure as yet what colour to do it yet all the parts are pipes are going black. the manifold will be silver or chrome,IMG_4575.jpg
today get all the bits ready the big day is here the car is going the paint shop in the morning after 2 years of messing about. all the bits ready IMG_4606.jpg
also today i made the holes bigger in the ducts to help get max amount of air to the intercooler. you can see here the one i just made bigger vs non modded one IMG_4601.jpg
while the car is getting painted just got a few more parts i need, vailside 3ich system. some brand new roof trims and some 555 injectors so the car can be mapped now for the bigger turbos. also got the other race logic traction control unit new in the box never used very lucky to find that, am using this one i like the old school dial on this one better than the digital on so the job is all go rite now and getting very expensive indeed IMG_4623.jpg
yes tom am changing the lot to 3 inch so am going to be selling japspeed down pipes and decats and mongoose system all in very good order but will be in a few weeks would like to sell as one whole system from turbos to tail tips
Give me first refusal then please mate.
its will be the lot top will pm you now
That's the setup I have. In case you don't have it here is the Z32 specific install (from TT.net):
http://www.twinturbo.net/nissan/300zx/tech/tc/tc.html
thank you, do you have full throttle shifts. in the box there is a extra wire that was send out to the first buyer we think i may have full throttle shifts. i have rung race logic but they cant be sure if it does or not just have to wait till its fitted i guess, did you fit it your self ?
I don't have the full throttle shift on my setup (it was an option I didn't purchase). You can read Racelogic's info on the
option here:
https://racelogic.support/05Traction_control/Traction_Control_-_User_Guide/09_-_TC_Full_Throttle_Shift
I fitted the RLTC system myself following the guide I linked to in post 93 above.
yes been reading there page a lot, am not sure if am fitting it or getting noel to it. am not really up on this kind on thing
today sorted the front lights out and converted to hid cleaned the inside out with a rag on a coat hanger, cleaned the rubber seals up and fitted hid kits you have take a side by side of the finished one and the untouched one same with the rubber one cleaned up and one not, used jizzer de greaser
THE LEFT ONE I WILL TO 2 MOZ YOU CAN SEE THE CLEAN ONE ON THE RIGHT
Edited by dan300zx
got the lights finished hids, with plug and play hard wired the oem plug on stripped the seal cleaned them and inside the glass and rear of case. IMG_4684.jpg
to day got my vice fitted in the work shop also my new front wing is here ffrom japan. 3 month been waiting the car can be painted . had a good sort through all the part cleaned up the stock valves as am refitting them, cleaned the pipes up to. and the seal that goes round top off fuel fitter found my new black matts, and a load of parts i forgot i had inc a cool knock sensor IMG_4728.jpg
i am fitted ducts to the 99 spec bumper so i have converted the 99 indicators to have side lighs in them to used smd strip looks a little blue in the pics here but looks white in really life. all done with solder and plug and play. hope you like them some pics a vid
