Build Costs of a zed
Just done my first draft of receipts from various suppliers and I have a running total of just over £16,000.
From what I have found here is the list I've compiled over the last hour which I will hand over to my insurance company.
Component Supplier Date of Purchase Total
300zx Drift Iridium Volt Meter Guage Z Centre 27/05/2010 £65.00
300zx Drift Iridium Oil Presure Guage Z Centre 27/05/2010 £65.00
300zx Drift Iridium Water Temp Guage Z Centre 27/05/2010 £65.00
300zx Radio Slot Guages Z Centre 05/07/2010 £25.00
300zx Car Private 14/08/2010 £4,500.00
Throttle Body Gasket Z Centre 27/08/2010 £14.00
Vacuum Hose Kit Z Centre 27/08/2010 £27.00
TT PCV Kit 5 Hoses Z Centre 27/08/2010 £73.00
Plenum Gaskey Z Centre 27/08/2010 £10.00
300zx Lighting Switch Surround Z Centre 27/08/2010 £25.00
300zx Centre Console Surround Z Centre 27/08/2010 £25.00
300zx Nissan OEM Water Thermostat Z Centre 13/09/2010 £18.00
300zx Nissan Plenum Gasket Z Centre 28/09/2010 £10.00
300zx S Type Skirts Car Mad Stylings 25/08/2011 £120.00
300zx Door Fillers Car Mad Stylings 25/08/2011 £20.00
Driftworks Traction Rods Driftworks 01/05/2012 £71.25
Driftworks Camber Arms Driftworks 01/05/2012 £97.50
Driftworks Hicas Eliminator Driftworks 01/05/2012 £46.50
Driftworks Toe Rods Driftworks 01/05/2012 £90.00
Driftworks Adjustable Front Camber Arms Driftworks 01/05/2012 £142.50
Driftworks Geomaster Tension Rods Driftworks 01/05/2012 £111.75
Nissan Rear Upright Poly Bushes Driftworks 01/05/2012 £13.50
Nissan Rear Upright and Control Arm Poly Bushes Driftworks 04/06/2012 £30.00
Driftworks Front and Rear Lower Arms Driftworks 26/06/2012 £200.00
Z32 Rear Bush Hub MJP 19/07/2012 £13.11
Oil Temperature Sensor Sandwich Plate Driftworks 31/08/2012 £50.00
Planet Performance 27/05/2013 £200.00
300ZX Engine Rebuild LA Autos 01/05/2014 £750.00
300zx Blue Print Gasket Kit Planet Performance 15/05/2014 £380.00
300zx Full Respray Deposit Planet Performance 02/06/2014 £1,000.00
300ZX 99 Spec Rear Spoiler Z Centre 03/06/2014 £192.00
300zx Full Respray Deposit Planet Performance 06/06/2014 £1,000.00
Various Replacement Parts MJP 20/06/2014 £1,274.62
300zx Catback Exhaust, Downpipes and Radiator Japseed 10/07/2014 £517.00
Performance 2 Stage Clutch for 300ZX Planet Performance 14/07/2014 £600.00
Clip Cowl Top Z 32 66860-01W01 MJP 20/08/2014 £8.70
Clip Cowl Top Z 32 66860-01W00 MJP 20/08/2014 £9.42
RHD Fairlady Z32 VG30DETT Main Engine Wiring Specialties 06/10/2014 $475.00
PRO Series Z32 VG30DE(TT) knock sensor subharness Wiring Specialties 06/10/2014 $18.00
Wiring Specialties Z32 Transmission Harness - 5 Speed - AT to MT Wiring Specialties 06/10/2014 $226.80
W/Strip Body Side/Targa Z32 76815-51P10 LH MJP 29/10/2014 £256.80
W/Strip Body Side/Targa Z32 76860-51P10 RH MJP 29/10/2014 £256.80
Z1 Silicone Turbo Accordion Hose Set Z1 Motorsports 11/11/2014 $192.00
Z1 Stainless Steel Intake Hardpipe Kit (TT) Z1 Motorsports 11/11/2014 $330.00
Z1 Stainless Steel Engine Bay Bolt Kit Z1 Motorsports 11/11/2014 $69.60
JDM Z32 Cruise Control Switch (RHD ONLY) Z1 Motorsports 11/11/2014 $68.42
Throttle Body linkage Spacers and Shims Z1 Motorsports 11/11/2014 $25.20
Polished Plenum work Mirror Metal 26/05/2015 £156.00
Polished Throttle Body Mirror Metal 26/05/2015 £60.00
Polished Centre Support Mirror Metal 26/05/2015 £12.00
Polished Water Pipes Mirror Metal 26/05/2015 £40.00
Nissan 300zx Rear Brake Caliper Kit Bigg Red Ltd 04/08/2015 £20.50
Nissan 300zx Front Brake Seal Kit Bigg Red Ltd 04/08/2015 £89.00
Nissan 300zx Rear Brake Caliper Piston Bigg Red Ltd 04/08/2015 £59.80
Nissan OEM 300zx Battery Cable Wiring Harness MT Z32 ConceptZ 07/08/2015 $96.28
Nissan OEM 300zx Rear Hatch Side Molding Clip Z32 ConceptZ 07/08/2015 $18.90
Nissan OEM 300zx License Plate rear Bracket Z32 ConceptZ 07/08/2015 $61.42
Wiring Specialties Corner Light Connector ConceptZ 07/08/2015 $16.68
CPZ 300zx Turbo Silicone Radiator Hoses ConceptZ 07/08/2015 $95.00
Nissan OEM 300ZX Outer Door Finisher Cap Z32 ConceptZ 07/08/2015 $12.74
Nissan OEM 300zx Complete Front and rear Wiper Arm Set ConceptZ 07/08/2015 $108.00
Nissan OEM 300zx Windsheild Washer Tank Cap ConceptZ 07/08/2015 $4.58
Nissan OEM 300zx Hood Latch ConceptZ 07/08/2015 $72.82
Nissan OEM Top Moulding ConceptZ 07/08/2015 $8.64
Nissan OEM 300zx Radiator Overflow Cap ConceptZ 07/08/2015 $12.50
Nissan OEM Rear Hood Seal Battery Cowl Z32 ConceptZ 07/08/2015 $20.26
CPZ 300ZX Silicone PCV Hose Clamp Set ConceptZ 07/08/2015 $9.54
Nissan OEM 300ZX Front Fascia Support Z32 ConceptZ 07/08/2015 $79.61
Nissan 300zx Power Steering Reservoir Tank ConceptZ 07/08/2015 $155.94
Nissan OEM 300ZX Door Pin Switch Boot Z32 ConceptZ 07/08/2015 $16.46
Switch Assy - Door Pin ConceptZ 07/08/2015 $38.45
CPZ 300zx Silicone PCV Hose Kit ConceptZ 07/08/2015 $94.79
300ZX Black Interior Retrim with Red Stitching HideNSeat 14/08/2015 £990.00
Nissan OEM 300ZX Brake Line Spring Clip ConceptZ 18/08/2015 $16.96
Nissan OEM 300ZX Brake Pad Shim Kit - Rear ConceptZ 18/08/2015 $59.47
Nissan OEM 300ZX Front Brake Caliper Fluid Line Tube LH Z32 ConceptZ 18/08/2015 $12.26
Nissan OEM 300ZX Front Brake Caliper Fluid Line Tube RH Z32 ConceptZ 18/08/2015 $12.26
Nissan OEM Front Brake Hardware Shim Kit 300ZX 90-96 Z32 ConceptZ 18/08/2015 $42.89
Nissan OEM 300ZX Hood Prop Rod Clip ConceptZ 18/08/2015 $2.65
Nissan OEM 300ZX AAC / IACV Valve Gasket Z32 ConceptZ 18/08/2015 $15.55
Nissan OEM 300ZX Ignition Lamp Assembly - Z32 ConceptZ 18/08/2015 $23.26
Nissan OEM 300ZX Steering Wheel Emblem Z32 ConceptZ 18/08/2015 $18.92
Nissan OEM 300ZX Turbo Outlet Hose LH Z32 ConceptZ 18/08/2015 $12.84
Nissan OEM 300ZX Turbo Outlet Hose RH Z32 ConceptZ 18/08/2015 $11.72
Nissan OEM 300ZX Turbo to IC Piping Clamp LH Z32 ConceptZ 18/08/2015 $12.31
Nissan OEM 300ZX Turbo to IC Piping Clamp RH Z32 ConceptZ 18/08/2015 $8.78
Russell 639560 Speed Bleeders Front or Rear Brake Calipers ConceptZ 18/08/2015 $64.32
Kuruma Z Quarter Window Moldings, 2+2 - Nissan 300ZX ConceptZ 18/08/2015 $85.00
Hel Braided Brake Lines 300ZX F P Automotive Ltd 25/08/2015 £50.00
Momo Gotham Leather Steering Wheel Rockshore 02/09/2015 £155.95
300ZX Steering Wheel Boss Z Centre 07/09/2015 £70.00
Nissan OEM 300ZX Radiator Clutch Fan Blade 90-96 Z32 ConceptZ 22/09/2015 $101.90
My wife has a mug that says-
"My greatest fear is that when I die my husband will sell everything to do with my horse for what I told him it cost!"
you are firmly in that boat mate
:lol:
I have 2 lists; one list is sent to the underwriters before I get a quote, which includes details and dates of literally everything I have done to the car. The other list is identical, except it contains prices! [emoji88]
After getting an "agreed valuation in principle" over the phone (at quote stage), when applying for the official agreed valuation certification, I submit the price list, another small list which details items that are cash purchases with no receipts (with a value over £100) and all the invoices/receipts (£100 or more) to quantify the first list.
The whole lot is scanned as one pdf document and forwarded to the appropriate people. The value is then confirmed (or denied) with a certificate. I'm assuming you didn't get the certificate?
:lol:
Yeah I was just about to say the other one, "my greatest fear is that when I die, my wife will sell my car parts for what I said they cost" :)
As my build was coming to an end and the car was just insured the paperwork was not long in the post.
But even if they did receive it, my guess is that it would disappear as I made a claim prior to them processing it.
I haven't a leg to stand on with them regards the valuation so i'm just giving my case with regards my costs of
the rebuild and all the pictures.
Its a big list but it shows the biggest buys within the last 6 months to a year as the build came to completion.
Was the lorry driver insured?
Surely if your insurance are pursuing his insurance it ought to be a little easier.
I would also say get yourself to Citizens Advice, one of your rights as a British Citizen is 30 minutes free legal advice on any subject.
They will put you in touch with the local specialist Solicitor.
I'm sure their advice will be refuse the first offer, also they could advise on pursuing the Lorry Drivers insurance or Company for any shortfall.
Either 30 minutes is long enough for that Solicitor to say if going legal has any legs.
meant to say "either way" in the last sentence
With the amount of money that you could lose surly it would be prudent to pay for a solicitor to give you advice asap
Mine's gone way over £20k + the price of the car! I've never answered to anyone, so I never care. :)
That's a snip in the ocean compared to some cars on here! Jaffa's and MadMax's for example are probably 5x that at least!
Haha mine is also 16+ but my missus doesnt say a thing. Shes a keeper. Not sure id listen anyway
I have no idea what mine cost, I don't think I want to. Just placed another order with z1, they have 5% off today btw
haha i stopped counting a while ago too bud ;)
