May 31, 201511 yr i know its a engine out job to replace the turbos. has it been done with the engine in have been reading a few online that say its been done, has anyone on here done it just wondering
May 31, 201511 yr There used to be a guy who had a few times, don't think he's active anymore. It's defiantly possible, question is, is it easier? Don't forget, access is only half the problem, the combination of that and rusty seized bolts brings a whole new dimension. I've eyed the job up before and I recon the drivers side, contray to first glance is likely easier. Because you can access all four manifold to turbo bolts quite nicely. The passenger side one of the rear two is a shit bag with the engine out let alone in situee, so most probably would demand the manifold to come out with it. The reward of pulling your engine is higher than most would assume. Because it allows you to solve half à dozen other issues you didn't even see before and remove previous owners tools etc that are in the engine :lol: hasn't hour gearbox got time off soon anyway? In which case that's a third of the work already done....
May 31, 201511 yr I haven't, wouldn't and couldn't!, but I have definitely read on this forum that it can be done with the engine in. By all accounts it is easier to remove the engine.
May 31, 201511 yr am going to pull teh box next week to fix that seal. i have not get the money at the mo to paint the car. so was thinking should i just pull the motor, then get the car painted and engine bay then just wait even longer till i can do the engine upgrades, or just pull the box get the seal done then get the paint done then do the engine next year, just dont no what to do now - - - Updated - - - could you get to the turbos if the box was off
May 31, 201511 yr It is possible with engine in but a pain in the ass..Pull engine and do it properly as there is always more rectifications needed/noticed when engine is out:)
May 31, 201511 yr the issue is money i was thinking about just chaanging the turbos if the engine ok and the remap it just for now till i can do a big build when i have more money
