Replacement rear windscreen
Anyone know where I could get a replacement UK rear windscreen from? Auto Glass (who my insurance use) say they can't get one.
Thanks,
Phill
Try Nissan
Or a breaker, just needs a delicate touch to remove it.
Rear screens were never made as a pattern part, in fact none of the glass was other than the windscreen which Pilkongton do. New ones from Nissan are around the £600 mark which are made by a Japanese glass manufacturer. I'd buy a used one if you can find a good one.
Last resort maybe?.. https://conceptzperformance.com/Cart/description.php?II=9416
Otherwise, if you get no luck with Mike and the shipping is extortionate (which I'm sure it will be) your best bet is a breaker. When I replaced all mine for UK blue tint glass, I managed to source quite a few UK bootlids. The blue tint is also found in factory painted blue JDM variants and all later spec JDM cars.
The part# for a blue tint 2+2 rear windscreen is 90300-37P00. The diagram below shows the various elements
used in its fixing. Try for a s/h one off a breaker.
http://nissan4u.com/parts/300zx/el_z32/1993_1/type_1/body_back_door_and_rear_body/back_door_panel_and_fitting/
Thanks guys
Apparently Nissan themselves can't supply, according to Auto Glass. I may call them myself just to be sure though.
Contacted ConceptZ... $800 shipping...
may be easier to buy a complete tailgate from a wrecker. That way you wouldn't have to mess about with the seals and trims and and with the money saved you could get it repainted.......
