2014 work in progress
Some of you may know I have an FB page documenting my progress, but since a few don't have/want FB, I'm going to start uploading pics here too as I get time.
As I've said before, not competing this year, time is being focussed on family and home projects, both of which I largely ignored last year! I also enjoy modifying and developing the car as much as driving it, so can tinker away at it through the year, so don't expect fast progress.
Open for discussion, criticism etc :)
Edited by jaffa
  • Replies 258
  • Views 26k
Figuring out new brake lines
First order arrived
Is that a chjn splitter! It's massive!
Lol, it was a sheet I used as a dummy splitter and to make sure the base of the bumper was flat. In the garage making the real splitter now
Bloody hell that's wide! Amazing effort that must have taken so many man hours. How big are the wheels you're planning to run?
I run a 265 at the front, may go wider to a 295 once I get some testing time. This was done to increase track width, a 295 up front is possible with stock arches with some care taken around offsets
:shock: 295 under stock front wings!!, I'm worrying about 295's on the rear!!:shock:
Getting ready to mould
Wing fixed after it's love tap with the wall at donnington and new mounts made.
Mould off on Saturday morning then over to jimmer to refit engine gearbox etc
I love this friggin thread!! It's amazing what can be done to these cars!! Keep at it Jaffa:clap:
Engine and gearbox in, prop on, fuel hoses for top feed finished, main coolant lines 50% done, brake lines I had are in, rest arrive tomorrow. More oil line fittings also arriving tomorrow.
Progress!
Edited by jaffa
So is your slam panel removable?
Is the mould so you can make another if that gets damaged?
The bumper and wings were made of expanding foam and a layer of filler, was only ever intended to make a mould out of it, couldn't be used as a practical item.
Slam panel is in the bin
Pushing ahead
Engine bay oil lines made and fitted
dry sump mandrel setup adjusted and fitted
calipers massaged to fit
Coolant line done
intercooler and piping fitted
sensors and Efi harness fitted
In car electrics fitted
Lots of customisation and fabbing so slow progress but getting there!
Not got many! Too busy getting stuff done
IC piping
Sump
And back at home, mould all cleaned up, getting ready to make the cf part
it runs, huge thanks to Jimmer and his contacts for fixing everything that needed doing quickly
Edited by jaffa
Will the car still be MOT'd and road legal?
That's the intention, though a lot to do before that
Will it be registered as a kit car?
I hadn't considered that, was just going to unSorn it at some stage
Gaz - finished is a very subjective term, still hoping to be at TOTB
