very strange
went out for a spin this morning as my zed has not seen the light of day for a few weeks ,,gave it a good blast down the road around 70ish after a few miles the steering wheel started shacking dropped back to 40 and still doing it.pulled over to see if the wheels had dropped a wieght but all looked good ,,pulled away and everything was ok all the way home ,anyone ever had this before?
lets hope it was just a stone i'm booked into a few cars shows in the next few months
Jack the front up and check for play, sounds like somethings loose, wherls steering arm etc. it would need to be a friggin rock to make the steering shake. All depends on how pronouced it is, you should still have a good inspect just in case.
cat didn't cross my mind i was thinking brakes lol
ย
My thoughts too mate.....
ย
...I had a similar problem last year; sometimes I'd get wheel vibe and others it was fine. Turned out to be a sticking front caliper - sticking intermittantly - until it finally seized altogether! Sounds like you could be having the same problem - and when you stopped, your braking action "unstuck" it, hence it stopped shaking when you pulled off again.
ย
Richard:cool3:
you could be right Rich thinking about it on the last m.o.t they said the drivers side was dragging alittle ,think a strip down will be in order
