Tappets, how hard/easy to replace?
Started my car up today to move it for the winter. Car runs fine but is very tappety. Since the engine came out of my old jdm and hasn't been run for any length of time since jan 2009, I kind of expected it to be like this. I feel pretty confident that once she's got a couple of hundred miles done the noise will reduce a lot.
However if it doesn't. How hard is it to change the lifters? Can it be done in the car or would I need to pull the engine. What's involved? I'm assuming plenum off, rocker covers off etc.
I've never done any internal engine work but I'm fairly handy with the spanners.
Engine runs lovely (fair bit of white exhaust smelling smoke, which I expected) but is really loud with the lifters. It sounds like there's a hundred of them horrible monkey things with the symbols banging together..lol
Id like to know that too actually as i actually have a noisy tappet, was thinking of just pulling the heads off my old engine and swapping them over, but i know that will be engine out as its going to be a pain in the butt to remove the manifolds with the engine in.
All because i have a noisy tappet on my passenger side bank lol
can be done in the car without removing heads...cams out and drop them in after soaking them in oil overnight right side up
That sounds all right then mate, you don't have a pic of the the buggers do you? I've only ever seen them in a 4pot..lol
Any guides ?
I'm sure Bri would love to sit down and do one for us tonight, since he such a nice chap :sailor:
they are really expensive, lol ordered a set for my rebuild engine as it has suspect noisy lifters, its cheaper to get them from the states then to get them from nissan uk.
Water pipes
Front cam belt covers
Cam Belt
Plenum
Cam belt Rear Dirt guards
Cam Covers
Cam Bridges
Cams out
all 24 hydraulic lifters are there to pull out
Water pipes
Cam Belt
Plenum
Cam Covers
Cam Bridges
Cams out
plus crank bottom pully off to replace the belt..dont trust thinking you dial the cams and belt in without sighting the crank TDC markings;)
yeah plus that too ...
List up date
Water pipes
Aux Belts
Main Aux Belt pulley
Cam Belt
Plenum
Cam Covers
Cam Bridges
Cams out
List up date
Water pipes
Aux Belts
Cam Belt
Plenum
Cam Covers
Cam Bridges
Cams out
lower plenum? lol
List up date
Water pipes
Aux Belts
Cam Belt
Plenum
Cam Covers
Cam Bridges
Cams out
we could add also in red things to replace while in there...
Cam oil seals
bloody hell, I'm really hoping the noise does quiet down now, or it's a party pack of wynn's first..lol
:rofl::rofl::rofl:
List up date
Water pipes
Aux Belts
Cam Belt
Plenum
Cam Covers
Cam Bridges
Cams out
Need changing
Cam shaft oil seals
Cam Cover Seals
Plenum gasket
Cam Belt
Voddy Center Intake manifold can stay in place
Just changed the cam belt and plenum gasket.. Should have done the bloody things when the engine was out. Just didn't think about it at the time..
Other than being a bit noisy will/can it cause any damage to the engine?
My old Vectra GSi had noisy lifters but I didn't mind that so much cos it hid the noise of the blowing rear manifold...:lol:
it shouldnt be a problem have u tried just an oil change for some thing slightly thicker ?
I've not really tried anything yet mate, I changed the oil for magnatec 10w/40 when I put the engine in, the car hasn't been on the road for 3 years. I'm thinking that a good run will sort it (fingers crossed)
needs a good canning down the motorway for 20 miles or so Dave...followers bleed down if left idle and normaly pump back up when up to normal operating temps.A start up for a couple of mins a week is not enough.
