August 26, 201214 yr please help needed, I have a problem with my battery going flat if I don't start it every day any ideas what may be draining battery when parked for more than two days.
August 26, 201214 yr Sure its not just time for a new battery, rather than a drain? If not, is it definitely charging when driving?
August 26, 201214 yr Have you checked the obvious like interior lights not going off, the boot light staying on for example? There is a way to test for a drain, with a Multimeter, but someone else will have to tell you how.
August 27, 201214 yr Ive not do it before or had this problem but you could try the following: charging the battery. fitting it to the car. Connect a multimeter to the battery showing voltage. Then systematically remove fuses and check the battery voltage each time you do. In theory you should see a voltage gain if you come across the circuit with the drain. unfortunately if you find the circuit responsible you will have to track it further to it components but its a start.
