Guess what .......................Engine out again
it never ends for me ..
looks like a may of blown a piston ...
soo its forged time looks like
but gonna be off the rd for a little time and going to
miss some shows looks like :(
any one got a good bottem end with forged parts they want to sell ?
  • Replies 264
  • Views 11.3k
its back on the rd ... Done my first 20 miles in it all ready :)
Well done mate, you've certainly broken some sweat over this one :punk:
Not a fan of the turbo tab washers are you. Are you heading down the Pod tomorrow?
turbo tab washers ... ?
will be at pod on sunday ... i have work tomorrow
I might see you on A1/M1 as im heading down early on the bike. The tab washers on the 4 nuts onto the manifold stop them coming loose as there is no washers on them and they are just plain nuts.
Doh ! ... yeah now i know ..
no there a bloody pain in the ass
betime i tuck them off again there was only 1 tab still on
will be setting off around 6ish .. will be on the m1 around 6:15 there abouts doing a steady 55mph
keeping her off boost and easy load
well done mark i must say tou really do sink yourself into something when you get going dont you. as i sai dto you as japfest your car has progressed so quickly.
its been hard I'm totally worn out ....
being at work 9>6 every day and then coming home working on car till gone 12ish
for the passed 2 weeks more so this week
all i want to do is sleep ZZZZZzzzzzzzzz
Well i got to the pod but not all well ...
had an erratic idle ... Found a vac line off ... :)
but all so had a Heat problem Temp kept on up and down like
an air block ... and on the way home is got worse and temp went just above 100c ...Way to hot
well anyways just take thermostat out ... with boiling water it was only opening around 2>3mm
not allowing the water to flow .. Stuck another one in and all is well
new one opens 12>14mm ish
all working fine now
Did you get that crankcase windage kit in the end Mark? What about a baffled sump or Accusump as I presume you will track it?
i didnt non of the above ... it will only see a few tracks a year but only for short time
the windage thingy ... what it didnt tell u on the site but only found out by doing some research
you had to butcher the sump pan to make it fit
the sump its self has quite alot of baffling all ready .. will just make sure its up at the right level
if not just a little more
  • 1 month later...
Engine is back together again :) after turbo sticking and damaging the new build i did a few months ago
so i got my self a set of new manifolds and uprated fuel pump
in the middle of making a parallel fuel rail thought i pain up some engine bits :)
had to get a new rail due to the machine shop not doing as i asked ... wanted it gas welding but instead they used ark-weld
the thing leaks like a sprinkler :( ... so going to retry again
