Guess what .......................Engine out again
it never ends for me ..
looks like a may of blown a piston ...
soo its forged time looks like
but gonna be off the rd for a little time and going to
miss some shows looks like :(
any one got a good bottem end with forged parts they want to sell ?
  • Replies 264
  • Views 13.8k
ok ... the lot should be here tomorrow/fri ...
was just pre thinking
Piston Gapping
Just reading the tech info on the rings ...
87.5mm Bore = 3.444"
i have to multiply this by top ring application size .0050 ( turbo/nos ) this comes out at 0.017" ( 0.43mm )
to me this sounds a little small ?
Engine build so far
Wiseco Pistons 87.5
Eagle Con Rods
ARP Stud Bolts
ARP Main Bolts
ACL Main Bearings
ACL Rod Bearings
GT2560'r Tubs
AMS Manifolds
740cc Injectors
JD Tuning
Uprated VTC Springs
Gates Racing timing belt
Comtec Head gaskets
New Oil Pump
NA oil jets
New Timing Sprocket
OEM Gaskets set
PCV Valves
Heads Ported/Polished
Valves Re-cut/Seated
Block Bored out
Unortherdox Pulley set
Lightened flywheel
6 Paddle Clutch
Dual 10" Fan conversion
2nd Piston Ring gap Spot on
1st piston ring needed Gapping all 6 pistons needed doing
Edited by MarkDerby
A bit of Porting of the heads to match the manifolds bigger holes
Original are 29mm high x 34mm wide .. now 35mmx38mm
just a note that the holes look a little rough ... they have been smoothend off
Edited by MarkDerby
More Porting
quite a bit of ally to take off to the edge of black marker
All Most Built
Edited by MarkDerby
Hi Mark, not sure if I have missed this in your thread, if you are using COMETIC mls head gaskets remember to have the head face and block deck machined to 50RA as specified by cometic. This is almost a mirror finish and is important otherwise you will get coolant leaks. I am building my forged motor with the same grocery list as you but will probably not use the cometics I have already bought and rather go for OEM HG as I am targeting max 450 BHP. Cheers
Very impressive Mark, looks great
the Main block was checked me and the machine shop .. and all was level and clean so there was no need for decking ... but the heads did get skimmed and this all ready had to go to the next thickest gasket
if i had the block decked just for the sake of it means i would all so have to get the 3rd thickest gasket and this then starts to rely more
on that to have the compression at the correct ratio
How did you work out which thickness gasket you needed Mark?
Hypothetical question: you had an engine and had no idea if the heads/block had anything off before your ownership, how would you go about finding the correct thickness gasket to get the right compression ratio?
ok theres a few ways to determine the correct compression on the engine but 2 of them involve tools that are quite expensive
so the easy way is knowing that your block is stock .........
then when you have any work done to it Machine shop should/will tell you how much has been taken off Heads/Block
the manufactures have Set gaskets at different thickness's
lets say 1mm is stock ... then it will go by 1.2 1.4 1.6 so on
so no machined heads u will use Stock gasket ...
if the machine shop as taken 0.1mm from head u have to use 1.2mm gasket
problem u all so get is u are decreasing the compression ratio a little ...
so the best is to get a Close'st match as Poss
if your Heads/engine is unknown then u have to have the Volume/compression ratio tested
Machine shop will have those spacial tools to work that out
Thanks, i've wondered that for years but never asked
Piston Gapping
no thats spot on Mark
Hi Mark, what I was trying to say is that the finish for composite head gaskets and Cometic steel head gaskets are not the same, I am not on about the trueness/flatness of the surface....50ra for mls gaskets is much smoother (almost mirror finish ) as apposed to normal head skim finish which you can see the machine marks. This is well known on the australian 300zx forums. Sorry for going on like a stuck record...I will shut the @#$% up now.
lol who said u was going on ....
its nice to have other ppl's input on things like this
Jesus Effin Christ you made short work of that didn't you? Now were you careful with the liquid gasket so none can get into the oil or water ways and cause you more grief?:biggrin:
Nice work mate :thumbup1:
Well its Running as from 10pm it started on the first fire ... ( after priming for few mins ) ..
Spent the morning with vody and his gear box
didnt start getting my engine in till 4pm
just need to sort
Rad & Fans out
Prop shaft
Exhaust
bonnet
inside trim ( gear leaver )
Clean in side and out
just need to sort
Rad & Fans out
Prop shaft
Exhaust
bonnet
awesome bud, looks like we are both going to make pod in the zeds this weekend lol
Great work Mark, you certainly dont hang around! :thumbup:
That`s what I was thinking!! top job
Not much left to do now ..
Front bumper
Take of Ramps
Bonnet
ECU Refit
Clean and Polish :clap:
all i can say is i'm fooking nackard
back,hands really stiff shed loads of cuts,crazes
all over my hands ... lump on my head
and i'm falling a sleep just writing thiZZZZZZZZZzzzzzzzzzzzzzzzzzzz
