Made some progress today. Cars up in the air, wheels off and I’ve been cleaning up the suspension and steering components.
Wire brushed, used jenolite rust remover, then some rust neutraliser and then I’ll hammerite it.
I think at some point in the future I’ll get it all done properly but this’ll really clean it up and prevent any more rust (mostly)!
By
RobHowl ·
.... dam that stuff makes a mess and potentially screws up your alternator!
Having serviced and cleaned the PAS pump I decided to AN the pump fittings and thought I would post in case anyone wants to do similar.
Parts used on the pump were:
2 x Banjo adapter M16 to -8AN
2 x M16 x 1.5 Banjo Bolt (I could have used the originals)
4 x 3/8BSP/M16 copper washer
Here are a couple of piccies...
Also changed all the connections on my PAS POT to AN -8
Finally I still need to weld a -8 female bung into the PAS feed pipe so that it is completely leak proof :hyper:
Then refit, re-plumb - Job done forever I hope! :)
