September 9, 200917 yr Hi, Where is the best place to buy an oil filter for an NA, and can you confirm that I need approximately 4 litres of oil max? Thanks.
September 9, 200917 yr Get it from Nissan and 4 litres of oil is enough. Fill her up to 3.5 litres, then use the dipstick to get the level right from then on. Oil can be quite slow getting to the Sump on the VG so carefull not to overfill.
September 9, 200917 yr Nissan for the oem , oh and ask for the washer :) the filter is the same tt / n-a have you had any prior issues going to Nissan though with it being an import? Edited September 9, 200917 yr by ck300z
September 9, 200917 yr Author Only bought the car 2 months ago so not had a reason to go to Nissan. Will they want to know chassis numbers etc? Do they refuse to provide bits for imports? If they do, where else can I buy one from? BTW, how much should an OEM be?
Hi,
Thanks.
