I'm fed up with either replacing or repairing my front bumper every few months just wondered if anyone knew of any poly ones i could get and rough prices?
cheers
carl
Get the stock TT fascia and fit the Stillen type 3 extension. You can get the Stillen Extension from Z1. Wings west and Stillen GTZ-R fascias are not particularly attractive. 99-spec can be sourced through either MJP or Zcentre.
Like so. Will match your skirts better. What would look even nicer is if you got the little hole smoothed in on your current skirts. Would give a much cleaner more slick look.
Actually, if you change the angle of your FMIC, they look really good sat behind a 99-spec fascia.
Not the most elegant of FMICs, but you get the idea. Trying to find one with a flush fitting FMIC.
what fmic?:hyper:
dan.:D
That would drive me nuts - the FMIC is not straight and the FMIC pipes are at different angles as viewed via the vents under the indicators. :smw:
YES I am that weird! :dance: Just does not look right! soz!
