May 16, 200916 yr for those who dont know, ive converted from NA to TT, (and auto to man) put intercooler pipes back together, started first time but died out. i had forgot to blank off the recircs. blankt off, started again first time, idled a little longer, sounded like was on 3 or 5 cylinders, then diesd again when tapped the accelarator. now it wont start :( it just turns and turns, had a little blip but wudnt fire. ive left it now as dont want to flood it. ive not had the gas pedal pressed in when starting, just started with the key nothing else fuel pump noise comes on when ignition is on. any suggestions?
May 17, 200916 yr Author just plugged in the standard electric sub fan, makes no difference. still wont fire & still gived same error code. just need someone to confirm the engine & radiater hard pipes need to be full of water for car to work (i woudnt think the sensor would know if there was water in there or not) or if i ned a new sensor on the radiater hardpipes of the engine
any suggestions?
