May 16, 200917 yr for those who dont know, ive converted from NA to TT, (and auto to man) put intercooler pipes back together, started first time but died out. i had forgot to blank off the recircs. blankt off, started again first time, idled a little longer, sounded like was on 3 or 5 cylinders, then diesd again when tapped the accelarator. now it wont start :( it just turns and turns, had a little blip but wudnt fire. ive left it now as dont want to flood it. ive not had the gas pedal pressed in when starting, just started with the key nothing else fuel pump noise comes on when ignition is on. any suggestions?
May 16, 200917 yr Author and the PTU is clean. the engine was working fine before in the TT car. its in the NA car now, (swapped fuel pumps, ECUs, all the bits needed for the conversion)
May 16, 200917 yr Author hmm removed fuel pump fuse, turned the car over for 10 seconds, put it back in, it starts again, idles, its on about 300rpm, stil sounds like on 3/4/5 cylinders (dont know but dont think its 6) idles for a minite then dies again. boost leak? the petrol in there is quite old i beleive, but it still starts???
any suggestions?
