oscar
Everything posted by oscar
  1. Hi after 11 years of ownership my 300zx is up for sale the car and I have been on the club for many good years. I have lots of pictures I email them to you if interested. spec of the car is below looking for £6500 Suspension KYB AGX Adjustable Shocks Eibach Pro-Kit Springs SPL Adjustable Front Camber Arms SPL Adjustable Front Tension Rods Driftworks Hicas lock out bar Exterior Veilside mirrors 4 way head light panel 99 Spec rear spoiler Interior Triple pillar pod Autometer oil pressure Autometer water temp Autometer boost Zcentre full two tone leather seats GReddy PRofec B Spec II Boost Controller Turbo timer unknown make from Japan Carputer with customised front end & datascan 7 inch motorized touch screen Engine Engine removed and stripped by Jimmer Block rebored cyl ends heads skimmed valve faces/seat recut Oem gasket set 87.5mm Wiseco forged pistons Crank journals polished ACL Race series main and big end bearings Cosmetic head gasket Pcv valves and breather hose kit water pump thermostat and bridge hoses Timming belt tensioner a both idlers 6 x deatschwerks 550cc injectors Z1 GT 525 hybrid turbos with new oil feed pipes Vtc springs AMS 02 sensors Act 6 puck paddle clutch Egr system removed Avi solenoids removed Pvr solenoids removed Divorced turbo elbows and decat pipes Z1 side mounted intercoolers Uprated rad with AlanZ rad bracket Ecu john Dixon 555 map tested to 17.psi Smithy’s S/Steel Air guide Slam Panel Smithy’s S/Steel Headlight Covers Aluminium Z Oil Cap Long life Full S/Steel Exhaust Apexi Induction S/Steel water pipes upper and lower Polished water pipes from block S/Steel intake pipes S/Steel fuse cover large/small S/Steel engine cover Wheels Inovit 18" wheels Brakes 350z brembos in black with 324mm rotors
  2. For sale a pair of brake calipers from a 91 tt good working order when removed offers p&p will be about £15
  3. Hi mines a 91 jdm black my paint code is 732 if that helps
  4. oscar replied to a post in a topic in Events - UK
    hi im in farnborough add me please
  5. http://www.camberleyautofactors.com/elvethamheathcarshow/ Any one going to this
  6. i have pair of black mirrors with all connectors on that i can split if you cant find a new 1 or cant fix that.
  7. yeah im up for this
  8. I Could be up for this on either date be good see some faces :thumbup1:
  9. oscar replied to a post in a topic in Events - UK
    42. Oscar (Paul) - Farnbourough
  10. Put meter on it mesure the current if its drawing any amps start with the obverse then start taking the fuses out if no joy then start with relays.If you have no joy PM me
  11. I know bracknell and those pictures of the car were not taken in bracknell they look like they been taken in japan
  12. could we get some tshirts made up for this event just an idear
  13. yes it is called Destinator 3 Navigation you have to use it with mapmonkey, if you need any help give us a pm has i have jst done this after using autoroute in the car which is a pain
  14. this right its colour code is 732 colour description is black p,m,2c akzo nis732 colour map 358h2
  15. me poss if it does'nt conflict with my hoilday
  16. oscar replied to a post in a topic in Events - UK
    yeah il would b up for this :hyper:
  17. hi i would goodyear f1s all the way i get mine for £90 a corner thats 17s 255 35, 235 40 :dance:
  18. Recieved a few days ago, fantastic calendar keep up the good work :dance:
  19. i got from RiceRocketUK top man
  20. dose this bit come off the bumper or is it a bumper remove job
  21. i had this prob it was the boot light when shutting it does'nt always switch the light off
  22. yeah im in for a convoy where do you wanna meet up
