westy
Everything posted by westy
  1. Does anyone have a drivers side rear quarter window for sale? Mine got stolen?! Thanks James
  2. Does anyone know of a drivers side rear quarter window for sale? Car got broken into last night and apart from destroying the locks they some took out and rear quarter window without leaving a mark, and then decided to take it!? Super odd! Thanks!
  3. I've been considering getting some new 18 or 19" alloys for a while. I'm after a nice stance, but nothing extreme. I'd also like the tires to have flat side wall with little or no stretch/bulge. I also need to clear 350z Brembos and discs at the front. At the moment I like the XXR 527 (http://www.xxrwheels.com/wheels/xxr-527), but they only do certain size widths and two offsets (+15 or +38). FRONT 8.75J +15 245/30/19 REAR 9.75J +38 265/30/19 Can this setup be made to work or am I miles off?
  4. I'm seriously considering a one piece prop. Would a manual TT running a NA diff require a different prop though?
  5. I'm after a non-leaking pair of these with the hoses, clips and vacuum pipes ASAP. Ideally in time for some work over the weekend.
  6. Thanks Jeff, I'll go down the AFM root. What happens if the boost can't escape then?
  7. Thanks Jeff, I'll give that a go. I assume that blocking them off isn't an option then?
  8. I've bought a Zed thats had a light(wish) front knock and is now suffering from a starting issue. Basically its starts for a few seconds and then stutters and cuts out, the engine seems ok when it is running so, I suspect that its a vacuum issue or something along those lines. While investigating I noticed that the recirc valves have been removed and capped on the inlet pipes but, there are still open pipes on both sides coming from the tubs in front of the rad. Could this be the cause of the issue? The car was an insurance write-off so maybe its been raided and the after markets BOVs have been removed. This pic might explain it better...
  9. Here are some pictures....one careful owner from new apparently!
  10. Anyone recognise this Z'd and know its history? I can see that its had some work done Zed World in the past but it would be good to know more. I've just picked it up and am hoping to use if for a TT conversion.
  11. Sorry, I was referring to Gaz300'z wheels.
  12. I'm considering purchasing a set of these wheels, what offset are running?
  13. Thanks Funkysi. I'd be looking at a set of 18's or 19's all round. It sounds like the 18's are the best way to go out of these two. What do yo think the best offset would be?
  14. After 6 Years my Z is finally coming out of retirement but, it deserves some new wheels. I'm looking to fill the arches without any crazy camber or intense arch work. The wheels will also need to fit with the 350z Brembo callipers and coilovers I'm fitting. I won't be going crazy low. What are you thoughts on these? 18" 9.5J Wheels with a offset +25 19" 9.5J Wheels with a offset +12 I'm happy to add spacers if needed. Cheers
  15. westy replied to a post in a topic in Events - UK
    hey guys, how about this early evening? http://www.streetnights.com/index.php
  16. This looks fairly promising... http://www.streetnights.com/index.php
  17. Crikey, I was expecting a bit more than that for some reason. What CC are you looking at with 88mm, about 3100? Thanks for the info...
  18. Does anyone know if its possible to fit bigger pistons and the maximum capacity you could reach? Cheers
  19. Thanks mate! My alloys are made by Ultralite but i forget which model they are now. I've seen a red Z outside a pub in that area a few times in the past, is that you?
  20. I've currently got the 4 Pot Diablo panel and lights it looks great and does suit the car but i'm considering changing to 99 specs soon.
  21. 99% sure that would have been me. Where you in a Zed?
  22. Thanks for your help guys!
  23. Does anyone know where i can get hold of a plain carbon fibre Z bonnet with no vents? Cheers!
  24. 245 post = time to get subscribe i would say! :)
  25. Given the choice i would have stuck with the standard rims myself but then everyones got different tastes. As long as you like them thats all that counts mate.
