spongey
Everything posted by spongey
  1. This is what im trying to find out if there IS 10mm allowance on the size because as you say it takes 335s and they dont look too big, look just about right bar the rubbing but if they are only at maximim meant to have the 10mm either way then they are 20mm over the limit. If im wrong about the 10mm allowance then it means the 335s can stay. Stretching tyres esp in the dub scene is the in thing but its not for me and can you imagine taking a corner with them stretched and just peeling off!!
  2. 335 is on there now and it rubs the lining on corners so i was thinking now that ive found out they are 12" wide and not 14" wide that i could drop a size say to either 325 or 315, theres pennies difference between them but i didnt want to put the 335 back on if they are too high. Otherwise its down the playing with the inside archs and i dont really want to have to go down that route.
  3. Wide arch is allready on there. The tyres on the rear are Pirrelli P-Zero's - 335/30/18 but if they are 12" wide alloys that means they should be anywhere between 295mm and 315mm using the 10mm either way. They work out at about £330 each :( and quite a few places do them but they arnt a walk in the shop available if you know what i mean so no quick side of the road changes for me :Rofl:
  4. Id buy the Pentroof car. That would be enough :D
  5. Whats the tyre size for those? Ive been told there is only a 10mm allowance each way so.... 12" = 305mm That means either 295mm or 315mm doesnt it? What would going to 335 size on them do?
  6. Dying to see them mate :) We may need to talk again ;) Hope the house move goes ok fella.
  7. Southbound by junction 15ish, around 12-1pm... Totally stock. Why do i only ever see red ones :rolleyes:
  8. Pics dave? Is this "that" thing you told me about?
  9. I was quoted £15-20 for the front from AndyZ (when he has them in) The rear one i couldnt find any cheaper then £39.99.
  10. The colour would be straight black, the kit needs sanding down and respraying as its in pretty bad shape paint wise and a few minor repairs. £800 isnt as bad as i thought so gives me an idea of what tocost up :) Once again.... cheers hunnipie Wayne
  11. As much as i really want to ive not replied in there :D
  12. Your a diamond Andy :bow: I wont be doing it thats for sure but ill show someone else how its done :rofl: :rofl: Cheers everyone. Just the repray question left plese anyone. Cheers again Wayne
  13. Ok new temp yellow switch clip thingy sorts out code13. Swap the turbo pipes which sorts out boost gauge. Anything else? How would i sort the base idle or is that fixed with the yellow clip?
  14. I dont think he would be too thrilled :rofl: Seems like a simple enough job to do then, When two people come back straight away with the same answer then thats enough for me. Air con seems easy enough, 4 wheel allignment isnt as exspensive as i thought. Just leaves that big thing needed and the paint touched up.
  15. Would the code 13 deff put it into safety boost? If i could see the hoses then i should be able to swap then over. One jubilee clip off....... one jubilee clip back on :rofl:
  16. Phew :) May be a stupid question but does any air con place do them or is this worth taking to a zed place? Any ideas on where to try?
  17. Andyduff - The idle seemed fine, dropped slightly when the climate was turned off but nothing major. You dont have any pictures of the hoses i need to swap do you please :D Greg- Newbury isnt that far from me mate and as you say for quality its worth travelling for so will give them a shout. Martin- If the condenser was fooked would it do everything the same BUT not blow cold air? Its working fine, all buttons and its clicking in the engine bay and idle still changes when its switched on? Cheers lads :bow:
  18. Directx9 Windows update Java Windows update Open your my documents, make it windowed and try and move it from one side to the other and should judder if its an update still needed. When you update, if it says reboot... do it then as soon as your back online windows update again, it will take ages but trust me i had this from sunday to monday last week and after making sure there is absolutley no more updates its fixed it for me. Try firefox aswell as IE7 and update while you have it and see if that does it too. If none of these help then CTRL.. ALT... DELETE and throw it at a wall as i have no more ideas :)
  19. I have no idea what you just said :rofl: :rofl: Let alone find the bits. I was with rodders today and he said he wished you didnt live so far away from southampton. Is that the only reason it would be doing it?
  20. Just reformatted mine and had the same problem mate. Install IE7, go to here....... http://update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us ...... and update over and over and over again untill there is no more updates for your computer and one of those fixes it. Make sure in internet options, advanced in the browsing section that smooth scolling is checked :) HTH Wayne
  21. Allright there vijay mate :) Anything you have or can personnaly recomend then send it my way mate. Do you know prices for both of those by any chance?
  22. 1st. Boost gauge sitting on "0" with the key in and not on and also on tick over , slap bang in the middle. Boosts fine and drives pefectly, the gauge goes up to around 9ish when opening it up. Clocks were taken out to have rings inserted could this be something as simple as a connection being knocked or moved? Was checked on datascan and no faults were found. Gave a code 55. No smoke either blue/white so was told it might be a boost leak. How do i find that out and what would it cost for someone to check that for me? 2nd. How much to repair and spray a front strosek bumper (scuffs-spiders cracks-chips), spiders cracks on the wide archs and repair a dent in the high leval spoiler and respray that in a straight black and who is best to go to? 3rd. Air con isnt working so might just need gassing but would need someone to check that over. 4th. How much to refurb split rim alloys and paint the centres black the same as the car? 5th. 4 wheel allignment, who is best to go to and how much would it cost please. Thanks for any help in advance :D
  23. Nope... http://www.metalhouse-ltd.co.uk/id16.html Bottom one is the one they are talking about :rolleyes: Cheeky coonts
  24. Cheers, I might add that to the list when im down. :)
