A idea i had for the rear lights
Depends if you reverse in the dark a lot. I do and I like to be able to see behind me so my reversing lights will be staying put. That doesn't look too bad as far as rear light conversions go as there is some truly horrific ones. Ivan
monster zed on fleabay
I'm sure they are Zender arches. Still nearly everything on that car just looks wrong. Ivan
Throttle bodies on my vg30det.
Will this kit still fit the VG30DETT then? Ivan
Donington - 16th March
How much is it just to spectate as I can see the track from the missus's house. Ivan
Happy Birthday!
Cheers guy's! Ivan
Silver on A52 J751???
Hello to you. Missus saw you on the A52 today near nottingham somewhere. Ivan
Black G reg near Uppingham
Hi :dance: Saw a black 300 G51??? (I think). you were traveling towards Uppingham and I was in a red new Freelander flashing my lights like mad and waving like a loon. Ivam
annnnnndddyyyyyyyduuuuffffff
Probably best not to go into the other reason. :x:
Any MOT testers about
Paul C is one mate. Drop him a pm. What is it you want to know? I work in a garage that does MOT's. Ivan
checked my timing
Inductive? My timing gun connects to a wire going to a spark plug and the other goes to the battery terminal. Which one do I have? Ivan
vibrations when setting off
Could be prop bearing although you can usually hear a plusing, vibrating sound at about 50. Ivan
On/Off Dead Cylinder Problem
Did mine with the engine in mate. Took about 4 hours I think. Ivan
Does this sound like injector problem?
Could also possibly be PTU. Ivan
Manifolds
XS power NOOOOOOOO!!!!!!! The guy's on SXOC tend not to touch them with a barge pole as the crack up like a Lee Evans audience. Ivan
What do people think?
I would not buy that gasket set as it says it's for VG30DE and VG30DET not the VG30DETT which says to me possibly it's a Z31 gasket kit. Ivan
Newbie needs help!
If it is the PTU try and get a series II one from a trader on here as they tend not to break down as much. Ivan
Stillen GTZ-R II front fascia
You mean like this one? Mickeyb's black Z Ivan
help needed please!!
I doubt the dett sensor resistor will be fubar. More than likely sommat else. Ivan
Any Techie experts out there i can pic their brain? Few issues..
Thats why it's always better to take it to a specialist that is recommended on here. Ivan
Changing wing, arch liner and front bumper.
Should take about 3 hoursish depending on your mechanical skills. Not that hard a job really. None of the bolts are totally inaccessible. There are 2 under each headlight, 2 under each wing edge and 4 in the middle if I remember correctly. On the wing there are some along the top and 2 under the sill I think. Ivan
Rear passenger side is higher
More than likely a broken spring mate, Ivan
A Warning
TBH mate in a straight line they are a piece of pi55 to drive. In the corners they are too you just have to not go flying round like you would in fwd or gwd (gash wheel drive). Ivan
part number for hicas bushes
Part number 55114 39F00. They are the ends of the rack with a hole in them that the ball joint goes through. Not sure on price though. Ivan
Nissan 300zx Vein of my life
Bet you don't get much rain on the rear window.....
Is it as good to drive in bad weather though.... Ivan
