High Explosive
Everything posted by High Explosive
  1. thanks daveman thats the type of help we are all members for good on ya m8 will try tomm bit late tonight.
  2. yep changed with my m8`s still no joy
  3. the main dont come on when on side it only comes on when i put full lights on carnt understand it..my clock in door light work just not the dash clocks rear and dip??have changed every fuse in car and all relays in front left stll no joy doing my head in.been on it all day.
  4. hi looked on the nissan disc at my light problem it shows the dim dip lamp control unit passenger side some where just wondering where it is. Is in inside the car or under inner wheel arch as the picture is crap and i can not tell. cheers chris
  5. Good work m8 looking well.
  6. thier must be someone out thier that knows what to do please help me i`m going mad>>>
  7. yeh their int i think but i`m going to try that one also thier is 2 at the botom footwell near to fuse panel with rubber cover going to try them too.
  8. def not fuse i have changed them all but none had blown in all three boxes and changed all relays too stll no joy do they have a dim unit or something that could have gone
  9. if it the same as minr m8 its the gel leaking from it is thier as wobble in the steering.
  10. HELPi have ind,main beam, the lights come on main beam no dip,no front fog,no back. the inside light on panel do not come on i can use rear heater crusie control but the fog does not come on have changed the unit complete still same the clock works but when lights switched on does not dim...have changed all relays with my m8 have replaced all fuses in footwell. please whelp me i`m going mad.... the original prob was the rear fogs were not attachend, we went to attach to switch. then the problem occured when i put my lights on first click nothing happens no clock dim etc...no lights on at front. when i turn switch to full lights main beam only comes on...no back but stll have ind and brake??? please help before the wife get a kicking basic when i switch the light switch one click i get nothing no lights at all when turned full get full beam only nothing else...:headvswal
  11. does the dimmer system has any fuse on
  12. changed the light switch too m8
  13. yes m8 checked?????still no joy
  14. yes m8 had a multi meter on them and got a buz of them all??
  15. checked them all and the relays still no joy?
  16. update i have no dash lights or front fogs too help
  17. hi please help, i was looking at the rear fogs that have had some sort of set up done, was trying to wire up to relay on radio dash were switch is for it. think i wired up wrong and my rear lights went off and the fronts are stuck on high beam, every thing else works less rear lights and normal beam the fog wires i tried to sort out go to the back lights ground and the power comes off the clock power???so how no back lights and front stuck on high i have swapped all the realays over with m8 but no joy?? HELP NEEDED
  18. hi just a quick one i have the infometer that lets me look at data it has plenty of to look at you can set it so it warns you when at a level. it has temp o2 1, o2 2 ,fuel,ignition. well lots of tech stuff were can i find the reading that the car normally runs at so i can set it correctly
