Help!!!!
hi
please help, i was looking at the rear fogs that have had some sort of set up done, was trying to wire up to relay on radio dash were switch is for it. think i wired up wrong and my rear lights went off and the fronts are stuck on high beam, every thing else works less rear lights and normal beam the fog wires i tried to sort out go to the back lights ground and the power comes off the clock power???so how no back lights and front stuck on high i have swapped all the realays over with m8 but no joy??
HELP NEEDED
You've got to start checking fuses first, sounds like you've blown at least one, if not more.
First check the fuse panel to the right of driver leg/foot, behind panel >>> Jap Translation Here
Next one is drivers side of the engine bay at the back,
And the main relay box also has fuses in there.
Dave
Oh, yeah, and a bit of punctuation would be nice ;)
Have you checked the ones by ur feet inside the car ?
yes m8 had a multi meter on them and got a buz of them all??
So u have checked all 3 fuse locations, wiring and Relays ! best seek a electrician ! Sorry mate. Unless you have blown the light switch its self. have you anyone you could swap with ?
not had any luck then yet mate
