Fitted em today
Fit my new Tein dampers today, What an easy job.Did it on mi own and once the car was on the axel stands it took less than 10 minutes per side for the front and about 15/20 minutes for the back each side.Only ball ache was having to remove the rear seat and rear trim to get to the turret tops.An easy diy job and all you need is a socket set, jack and some axel stands.Well chuffed. :hyper: :hyper: :hyper:
Good on yer! Bet you feel great now it's done.
Not had a fiddle with the ride height yet,just fit them as they came out of the box.They will lower quite a bit more though.PS.she needs a wash.
If i get time 2 moro i'll drop her down within an inch of her life and post pics. :rofl: .Did i say inch?I meant millimeter.
Is that a Smithy's 324mm DBA disk I see there? Are you pleased with them? I fitted my boost controller today and my big brake kits that is on back order with Smithy can't come soon enough!
I have 17" Anz alloys and the brakes are the big brake kit from smithy,DBA 324mm slotted and cross drilled(They are only slotted in the kit but i payed extra and got them cross drilled as well).See my rides for more pics of the brakes.
They certainly stop you,there huge.Look at the size difference to standard.
I must been half asleep, you sent me a PM about them before, hopefully I’ll have my set in a week or two!
Christ, looks like they only just fit inside the rims!
Just gauging how big my 18's are going to be in the arches that's all, mine's standard suspension
Had to fit spacers mate.The kits spot on but certain wheel styles foul as i found out.Would reccomend this kit but u may have problems.If you do just PM me and i will help u out.
