In memory of Mandy
Air/Fuel Gauge
Hello, im going to be installing a Air/Fuel gauge tommorow and just wanted to know if one of the connectors in the top of the engine bay for the o2 sensors is where i want to tap into? and which wire do i need to splice?
My gauge only needs one wire to slice.
Pete
ok, the gauge is installed on the pass side o2 sensor, and im getting no reading, any help?
1 wire???? dont these things need a power feed aswell?
is your sterio positive feed live all the time because most modern sterios have two live feeds but only one is perm live.
duh? i meant only a single wire to splice, its tapped into the sterio power.
are you being sarcastic here????
what i meant was, the gauge is working and geting a reading, but... it doesn't change.
Its a glowshift volt/air/fuel gauge, the volt reading is good, but the air/fuel is showing red only, which means its getting a reading from the o2 sensor, but it doesn't change.
And i know its getting a reading because i previously had it installed to only power and it gives a reading for the volts but doesn't light up for the A/F, just displays a flashing warning.
duh? yep
more info=more help:slap:
Edited by znut
Well that buggered me, lol cos the ECU is a closed loop application you won't get a proper reading for the 1st 2000 revs. Mines wired into the loom at back of ECU but it certainly has 2 or 3 wires from it.
Soz can't help in that case.
smithy
whats funny is i would wire it into the driverside o2 sensor but when i look under the car i can see the wire from it has been cut for some reason, its been like this as long as i have had the car and it runs fine, wierd eh
I think ill do a o2 ecu check thingy tommorow
I noticed today that the gauge reading changes depending on things switched on in the car ie. heaters, redimister etc
So, i must be getting interference from somewhere eh?
Can anybody point me in the direction of the ecu pin numbers the o2 sensors are so i can just tap into the wire at the ecu end instead.
Pete
TBH theose gauges are less than usefull.
Being a narrowband sensor its nothing mire than pretty lights im afraid.
The only way to get accurate reading on your A/F ratio is with a wideband :)
i know mate, but they give you a rough estimate of how things are running, which is all i need, mild mods and so forth
Pete
bump
Thats what i would have said, im still to fit my innovite wideband.
Pete you need to locate the ecu o2 pin and splice it in there. There is a ecu pin diagram somwhere floating about, have a search.
