Fuel pump fuse and regulator question
Hi, does anyone know which and where is the fuse for the fuel pump on a 91 J Spec.
Also motor appears to be overfuelling. Can anyone tell me what direction on the screw to reduce fuel?
The fuel pump fuse is in the small fuse box in engine bay, next to the brake master cylinder.
There is no fuel adjustment. Everything is controlled by the ECU. Most likely Overfuelling reasons are bad o2 sensors, bad coolant temp sender, bad fuel pressure regulator, boost leak...
its the green fuse on the end,
mine was overfuelling, clean the PTU (search that)
