and it aint the uk weather, my rear sill rotted and i replaced them all, they rotted cause of the rubber targa drain pipes rotted and was leaked inside the sills hence the rust
my rear footwell needed a patch putting on, this was due to the rubber targa seal leaking water into the cockpit and it corroded from inside (all repaired)
im n the process of replacing my front crossmember, this is cause nissan decided to put a pipe that runs from some type of water bottle inside the crossmember and its open ended and it just leaks the water into the crossmember
so its nissans rubber hoses that cause the rot, not the fookin weather:headvswal
