Washer motor
Anyone know the easiest way to gain access to the washer motor? Is it attached to the washer bottle? I'm kind of guessing it may be through the wheel arch but thought it'd save time to check before pulling bits off.
Yep its built in to the washer bottle. This is under the RHS front wing
IIRC you will need to remove the front arch liner to get to it.
Just had all my front off and i can confirm once you've got the arch liner off you have good access to it. :)
